Trigger actions from http (API) request emit from the ESP
Schmurtz
#1 Post by Schmurtz » 06 Jan 2017, 11:11
Sorry if my question are obvious for you, I didn't know ESP easy before today ;)
I would like to send IR signals when a request on an API returns a result.
So my questions are :
  • 1 - is it possible to query an API from ESP easy to trigger an action at regular intervals (like sending an IR signal) ?
  • 2 - is it possible to parse a json result from a web API ?
For example a result from my API :
{"type":"0","ch":"0","mode":"31","loop":"0","eq":"0","status":"pause"}
I want to send IR signal when "status" is 'play".
I already found how to send IR with this post.
But it seems that I want to divert the use of ESP easy : it seems more to be a slave device controlled by home automation and it is not made to be autonomous. I'm I wrong ?
