220V AC mains detector (slightly OT)
data
#1 Post by data » 26 Jan 2017, 11:30
Does anyone know of a ready available 220V AC mains voltage detector module utilizing an optoisolator/optocoupler from China (AliExpress, ...)?
Although pretty simple, I do lack the time to source parts and build them. However, I haven't spotted one on Ali yet.
The only thing that could be probably utilized is this 4x optocoupler module: http://s.click.aliexpress.com/e/72vVnyB
However, in order to work with mains voltage, I still would have to add a capacitor and a rectifying diode at least. And the main
problem I see is, that it's inputs aren't sufficently separated from each other in order to use it along with low voltage sources.
Any suggestions welcome!
Background: I have an electric door opener working on 12V DC and a 220V ac motion detector installed and would like to monitor
both with an esp easy module connected to domoticz.
mrwee
Re: 220V AC mains detector (slightly OT)
#2 Post by mrwee » 26 Jan 2017, 14:51
230V Solid State relay?
JMJ
#3 Post by JMJ » 26 Jan 2017, 15:46
I have a similar project, and i will use this;
http://www.ebay.com/itm/252642089895
data
#4 Post by data » 26 Jan 2017, 17:06
@JMJ: Thank you, this is, what I've had in mind. Will have to search ebay/ali though, since the one linked by you does not ship to germany.
@mrwee: Thank you, I will look into this as well, depending which option might be cheaper.
Users browsing this forum: Anthropic Claude Bot [bot] and 14 guests
