Saved custom task setting disappears after a while
buzink
#1 Post by buzink » 29 Jan 2017, 14:48
I need a variable for the plugin I am creating that holds the name of a template (like "[Import1#tablelamp]"). I successfully added a new element to the form. It saves the entered text and also loads it next time I open the device page. If I then close and open the page again, the text is gone. I'm new to C, so probably I am doing something obvious wrong. I am most unsure about the char deviceTemplate[8][64] bit. Below is my code. Who sees what I have done wrong?
    case PLUGIN_WEBFORM_LOAD:
        char deviceTemplate[8][64];
        LoadCustomTaskSettings(event->TaskIndex, (byte*)&deviceTemplate, sizeof(deviceTemplate));
        string += F("<TR><TD>Initial value template");
        string += F(":<TD><input type='text' size='80' maxlength='80' name='Plugin_198_template1' value='");
        string += deviceTemplate[0];
        string += F("'>");
     case PLUGIN_WEBFORM_SAVE:
        char argc[25];
        String arg = F("Plugin_198_template1");
        arg.toCharArray(argc, 25);
        String tmpString = WebServer.arg(argc);
        strncpy(deviceTemplate[0], tmpString.c_str(), sizeof(deviceTemplate[0]));
        //Settings.TaskDeviceID[event->TaskIndex] = 5; // temp fix, needs a dummy value
        success = true;
     case PLUGIN_TEN_PER_SECOND:
          String tmpString = deviceTemplate[0];
          if (tmpString.length())
            String newString = parseTemplate(tmpString, 20);
            Plugin_198_initlevel = newString.toInt();
