Globaltronic Protocol Issue - One Sensor as two devices?!
data
#1 Post by data » 02 Feb 2017, 10:53
I just noticed a strange issue with a temp/hum sensor I am monitoring.
This sensor appears as two separate devices, depending on the temperature:
This is, how it looks in domoticz below 0 degrees:
03BF 0 GlobalTronics Temp + Humidity WTGR800 -0.1 C, 70 %
And now above 0:
00BF 0 GlobalTronics Temp + Humidity WTGR800 3.6 C, 88 %
Can this be fixed in RFLink?
Stuntteam
Site Beheer
Re: Globaltronic Protocol Issue - One Sensor as two devices?!
#2 Post by Stuntteam » 02 Feb 2017, 11:05
Yes, it can..
I will send you a test version asap.
data
#3 Post by data » 02 Feb 2017, 12:30
Thank you very much!
data
#4 Post by data » 10 Mar 2017, 23:11
This bug is fixed in R46!
Just a few minutes ago, outside temperature dropped below zero
and I can confirm, that the temperature is being reported correctly
now in RFLink R46 (beta).
Thank you for fixing this bug.
