MPU6050 [SOLVED]
hamster
MPU6050 [SOLVED]
#1 Post by hamster » 25 Feb 2017, 14:32
Hi, Please can someone help? I'm struggling to add a MPU6050
1. I downloaded the latest easy version - https://github.com/letscontrolit/ESPEasy
(this includes MPU6050's) https://github.com/letscontrolit/ESPEas ... PU6050.ino
2. Uploaded from arduino v1.6.11
3. Once online I found no dropdown option in devices for MPU6050??
I'm sure i'm doing something wrong, but I can't seem to work it out?
Any one know? Many thanks
I also don't see the _P186_Ventus_W266 option or _P120_Thermocouple
[img]
Screenshot from 2017-02-25 13-25-27.png (98.82 KiB) Viewed 6167 times
[/img]
Piet
Re: MPU6050
#2 Post by Piet » 26 Feb 2017, 13:49
hamster wrote:Hi, Please can someone help? I'm struggling to add a MPU6050
A week ago i got it working with the P118_MPU6050.ino from the playground. (compiled and uploaded with arduino ide)
Today i pulled this updated P118_MPU6050.ino and got the same trouble as you have.
As a workaround comment:
//#ifdef PLUGIN_BUILD_TESTING
//#endif
Already tested last week with this plugin and my washer and it seems to work well (although i have to investigate for best settings). :!: Thank you JustMe-NL for this plugin!
hamster
Re: MPU6050
#3 Post by hamster » 26 Feb 2017, 14:22
Thanks Piet.. that worked
Much appreciated :)
psy0rz
Re: MPU6050 [SOLVED]
#4 Post by psy0rz » 27 Feb 2017, 10:25
officially you would have to add
#define PLUGIN_BUILD_TESTING
to espeasy.ino to enable all testing plugins.
we still have to update documentation for this.
Your workaround should is fine as well if you only need this plugin.
Piet
#5 Post by Piet » 27 Feb 2017, 19:44
Thanks for explaining, you are doing a great job for the ESP Easy project!
