Hi All,
I have esp easy buil 147 RC8 running on a sonoff SV.
And I love it.
But I cannot get a DS18b20 working on it.
The same device works fine on a GPIO 2 of ESP8266 ESP-01 chip, but not on the Sonoff SV.
It has GPIO1,3,4,5, and 14 available, but none of them work.
When I add the device it gets as port "0-0-0-0-0-0-0-0" and as value "nan"
I added it correctly, te sameway as I did on the ESP-01.
Does anybody know how I can get it t work?
DS18b20 only working on GPIO 2?
Re: DS18b20 only working on GPIO 2?
can't say what's going wwrong with your sonoff.
I have DS18B20's working on different GPIO's without problem on my ESP's.
Did you put a pull up resistor from the GPIO to 3,3V? (10 KOhm)
If you use GPIO 4 or 5 there might be the I2C active on these pins.
You may set the I2C pins in the "Hardware" Tab of ESPEasy.
thanks for the answer.
Ic2 is turned off completely.
Yes there is a 4.7 K resistor between the data and the VCC
hm...
maybe the DS-sensor is broken?
Try another one or connect it to another ESP for testing.
Did an interesting test.
Powered the ESP-01 from an usb to serial adapter, plugged in to socked, the sensor works fine.
Powered the ESP-01 from the Sonoff SV: ESP-01 runs fine, but the sensor not, althugh still attached to the ESP-01
Ooooops?
hm... does the Ds still get power?
Maybe put a capacitor around 100µF near the sensor between 3,3V and ground.
The DS takes around 5 µW so it is not likely it overloads the power supply of the sonoff.
Maybe the 3,3V line isn't really "clean".
Very strange,
I applied an external power 0f 3.27V but it does not help, I still get nan and address 0-0-0-0-0-0-0-0.
So plus and minus to external power supply, data to GPIO pin, 4.7K resistor between data and plus.
sounds a bit like a lost or bad ground connection.
Users browsing this forum: Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 16 guests
