ESP8266 Dry Relays contact
I'm planning to connect my Gates (exterior and garages) to my domoticz server. As I'm totally newbie I'm reading a lot but I would like also to order the components.
The 3 gates are automated with Nice appliance (POPKit/POA1 & Nice Spin 6021).
I can use a dry contact on the motor unit but I'm thinking of using dry contacts on the remote in order to be able to separate the open and closed orders. I will need one Flor4s, one flor2S and 6 Dry relays (I'm not sure of the english world. I mean a relay NO/NC without power on the output)
I originally thought to place a ZK1PA and to control it with RFLink but I'm a little worried about security.
So i would like to do it with a ESP8266 but I didn't find how to connect it with a Dry relay. I'm a little lost, and each time i found something there is power on the relay output.
Could you please help me to identify how to realize this and what shall I order ?
Thanks a lot for your feedbacks.
Laurent
Laurent
Re: ESP8266 Dry Relays contact
HiLoTheGeek wrote: ↑17 Apr 2017, 10:58 Hi,
Laurent
Let me make sure I understand what you mean correctly: you need relays with potential free contacts (as in no power connected to it)
If that is the case, then yes you can do that with esp easy. I use them to immitate "button pressed" on a remote for my blinds (dont have RFLink) just soldered wires parallel to the button and connected to relay.
check the wiki, there are plenty of relay boards (1 to 16 relays per board) that can be driven with the 3.3 V TTL level of ESP. Just check
https://www.letscontrolit.com/wiki/index.php/Relais
https://www.letscontrolit.com/wiki/index.php/GPIO
Thanks a Lot for your answer
Yes, you understood what I want to do.
Is something like the following items Will work ?
https://m.aliexpress.com/s/item/32685596353.html
https://m.fr.aliexpress.com/s/item/32714920351.html
I Will need to power it with something like this
https://www.amazon.com/Breadboard-Modul ... B01MT640P8
Which esp8266 do you recommend to pilot it ? Can I control the 6 relays with only one esp8266
Is everything compatible with breadboard ?
Laurent
Laurent
these relay boards should work, at least the ones I have tried do work.
For six relays you will need at least a ESP-07 or better an ESP-12E or 12F.
The smaller ones do not have enough GPIO pins.
But the ESP's usually are not breadboard friendly.
If you want to do breadboard testing i'd recommend a NodeMCU V3:
https://www.aliexpress.com/item/NodeMcu ... 6dad0c2e74
The NodeMCU contains an ESP-12E, the USB to TTL converter for flashing and monitoring the serial port and the voltage regulator from 5V to 3,3 V.
So anything you need is already on the board. Usually they run on power from the USB port of a computer but it is possible to supply 5V externally
with the NodeMCU too.
The NodeMCU is breadboard friendly.
Just the relays need a separate power supply, usually 5V.
I recommend to keep power supply for relays and ESP separate.
As all pins from the ESP is led out to pins you have enough pins for 6 relays and still GPIO's left for an I²C sensor or something like that.
Yes they are all fine. If you are starting and don't have to watch every cent you are spending, I also highly recommend using dev-boards. NodeMcu is a good choice, Wemos D1 pro mini (possible to connect external antenna if range is an issue), Wemos D1 has awesome power regulator (up to 24v input, 5v source to power relay). It is possible to power the relays from the same 5V power source than the esp, provided that it can give enough current ( a large elko helps).LoTheGeek wrote: ↑17 Apr 2017, 16:02 Thanks a Lot for your answer
Laurent
http://www.ebay.de/itm/401253107459?_tr ... EBIDX%3AIT
Dont buy single ESP modules, it will frustrate you.
If you need many more outputs check out the I2C port expander, I think up to 64 relays per esp are possible
Thanks for your help
I will order a wemos D1 mini
I only need to learn how to solder
Any advice on a good AliExpress Shop to purchase wemos relays etc...
Laurent
Laurent
I just ordered here : http://www.ebay.de/itm/16MB-WeMos-D1-Mi ... 3f6ca8bd83
But be aware that upon boot the relay might trigger causing the ESP to halt the boot.
An expansion board fix that problem.
PCF8574 I2C Interface 8-bit IO Expansion Board I/O Expander I2C-Bus Evaluation Development Module
http://s.aliexpress.com/EvAbmAf6
(from AliExpress Android)
But this is not mentioned anywhere in the wiki...
Thanks for this warning
Could you please give me more details on where shall I connect this expansion board and how to use It ?
That problem occurs only on certain GPIOs (2,3,4,15). Usage of the I2C Expander is in the wiki, fairly easy: connect to I2C, Vcc and GND and then look in the wiki for command reference. Even better, you can daisychain these modules=put up to 8 modules after one anonthergrovkillen wrote: ↑18 Apr 2017, 17:36 But be aware that upon boot the relay might trigger causing the ESP to halt the boot.
GPIO 16 as well.toffel969 wrote: ↑18 Apr 2017, 18:46 That problem occurs only on certain GPIOs (2,3,4,15). Usage of the I2C Expander is in the wiki, fairly easy: connect to I2C, Vcc and GND and then look in the wiki for command reference. Even better, you can daisychain these modules=put up to 8 modules after one anonther
Just to be clear, the warning about GPIOs triggering relays on boot is not mentioned. (Should be stated in the ESPeasy GUI when choosing the relay plugin...).
True...grovkillen wrote: ↑18 Apr 2017, 19:30Just to be clear, the warning about GPIOs triggering relays on boot is not mentioned. (Should be stated in the ESPeasy GUI when choosing the relay plugin...).
Thanks to everybody.
I will place my purchase order. I may require more help when I will receive it.
Meanwhile, I will continue to study.
I will of course keep you in touch with the developments
Laurent
Laurent
Hi againgrovkillen wrote: ↑18 Apr 2017, 19:30Just to be clear, the warning about GPIOs triggering relays on boot is not mentioned. (Should be stated in the ESPeasy GUI when choosing the relay plugin...).
As far as I know the relay is not an plugin as such but just a use case of digital output of GPIO pin (can be monitored with the switch device).
I updated the wiki with the info from this thread + some info about solid state relays. If you don't mind please check through it and edit/let me know if you agree. @shardan could you do the same?
best regards
Great update. Two things;toffel969 wrote: ↑18 Apr 2017, 22:28 Hi again
best regards
1. What if the relay board must be fed with 5V TTL logic? Mentioned a level converter? Also possible extra page with how a level converter work? Pictures of different kinds?
2. Mention that a I2C GPIO Expander board might be a good solution to avoid false trigger during boot?
Great work though!
Thanks, will dogrovkillen wrote: ↑19 Apr 2017, 05:47Great update. Two things;toffel969 wrote: ↑18 Apr 2017, 22:28 Hi again
best regards
Great work though!![]()
Depends on the internal circuit of the relay boards. But first some Basic things.
The Relay boards use 5 V. The ESP / NodeMCU / WeMOS uses 5 V.
Sounds easy, one power supply does it all.
Besides the relays may give some interference to the voltage leading to unpredictable behaviour there is another reason for using two separated powersupplies.
These relay boards use optocouplers for a good Isolation ( up to 3000 or more volts! ) between the ESP and mains voltage.
The signal is transfered optically, so with a good realy board there is no connection necessary between the relay voltage (5V) and the ESP voltage (5V).
Not even a ground connection between the both circuits is necessary with a good relay board.
If you use same power supply for both circuits you "bridge" between the relay circuit and ESP circuit. Why then buying a good board with optocoupler?
In wich way your relays behave on "power on" state depends how the relay board is working inside.
I can't see that from the photos. I've used this one for some testing with the PCF8574: .
The shown module has "negative logic": you have to connect the input pins to ground.
That works quite nice as the PCF8574 seems to set all outputs to "high" on startup so nothing happens.
Setting an output to "0" via http ( http://<ESP IP address>/control?cmd=pcfgpio,<pin>,0 ) switches the relay on and vice versa.
The big advantage of the PCF8574 is the expandability. Using the I2C-lines you can expand to 8 x PCF8574 + 8x PCF8574A
( the "A" type has another address range ) this giving 128 possible outputs in theory ). Anyone did that? I'd be curious to see it.
All that can be driven by a very small ESP-01.
If you don't need expandability i'd recomment a "Linknode R8" module made by Linksprite:
It can be found at Amazon and others. All in one small module, 8 relays + ESP-12E.
ESPEasy can be flashed easily with a USB-to-TTL programmer, the pin header is already soldered to that bard.
Beware, the programmer must have 3,3V output. The ESP will fry when using 5V.
Is this aimed for me? Or a general add-on to my thoughts?
Soory, i took your post as an answer to the threadopener....
removed it from my post.
Thanks Shardan
This is exactly what I need. However I already placed my orders. Next time I will look at this.
It may also help someone else
Best regards
Laurent
Best regards
Laurent
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot], opensiteexplorer.org/dotbot [bot] and 48 guests
