Which are the supported peripherals for measuring the mains voltage ?
dugolf
#1 Post by dugolf » 01 Jun 2017, 06:51
Domoticz V3.7602 on raspberry
RFLINK V1.1 R46 with 433MHz
I want to display the main voltage (230V). Which are the supported peripherals for measuring the mains voltage ?
costo
Re: Which are the supported peripherals for measuring the mains voltage ?
#2 Post by costo » 01 Jun 2017, 14:59
I use a Sonoff-POW to measure the main voltage. As a bonus I can measure current momentary power(Watts), cumulative power usage (Wh/kWh) and can also control the internal relay with Domoticz.
But this device ´cannot´ be flashed with ESPEasy nor will it work with RFLink but Domoticz can work perfectly well with this device when it is flashed with Espurna firmware.
