Fine Offset WH1080, WH1081 868MHz is not recognized?
Posted: 05 Jul 2017, 09:26
by WeatherOffset
I have a Fine Offset WH1080,WH1081(Proove WP1400) weatherstation with 868MHz sensor and that is not recognized by the RFlink gateway with a 868MHz transciever mounted. Other sensors are received.
Is this a known issue?
Re: Fine Offset WH1080, WH1081 868MHz is not recognized?
Posted: 05 Jul 2017, 13:58
by Stuntteam
It should work.. make a debug log and mail that to me..
frankzirrone@gmail.com
Posted: 06 Jul 2017, 11:41
by WeatherOffset
Ok, thanks!
I have sent you an email now!
Posted: 29 Aug 2017, 14:22
by WeatherOffset
Hi again!
I found some information about Fine Offset WH1080, WH1081. It seems like the have changed the protocol in 2012 from OOK modulation to FSK modulation in the protocol for the new units.
My unit is from 2007. Is OOK protocol supported by the RFLink 868MHz version?
Posted: 30 Aug 2017, 13:21
by chrille
WeatherOffset wrote: ↑05 Jul 2017, 09:26
What module are you using for receiving 868 MHz? CC1101? I have a WH 1090 which I think is very similar on the radio interface and would like to test that
- Jan
Posted: 30 Aug 2017, 13:59
by Stuntteam
RFlink supports the OOK version using an Aurel 868mhz transceiver
Posted: 08 Sep 2017, 09:24
by Grant Hall
Ok, I'll give it a try.
