[SOLVED] BHT1750 no measurement
pula001
#1 Post by pula001 » 06 Jul 2017, 18:56
I am trying to get a BHT1750 working on a Nodemcu V3 using espeasy core version 2.3.0.
Altough the sensor is recognised when I do a I2C scan in the web-interface, the brightness is always 0.0.
I did not use any pullups and used GPIO-5 and GPIO-4 as I2C-Pins and I used the 3V Pin on the Nodemcu for power.
I also have a PIR sensor on this, which is working as it should...
As I tried 3 different BHT1750 sensors, I suppose, that this is not a sensor problem.
Would anyone have a hint please?
Thanks and regards,
Pula
Re: BHT1750 no measurement
#2 Post by Shardan » 06 Jul 2017, 20:13
please offer some more info, otherwise it's difficult to help.
Which version of ESPEasy?
Screenshot of the device settings.
If you're using a R120 or R147 you have to set an IDX number.
Otherwise you will receive "0" always.
pula001
[SOLVED] Re: BHT1750 no measurement
#3 Post by pula001 » 06 Jul 2017, 20:23
thanks for your help!
Just updated to v2.0.0-dev10 - now everything is fine. Seems that in the stable branch there are still some issues or something.
Nevertheless. Now it works. Thanks a lot!
Cheers,
Pula
Users browsing this forum: Anthropic Claude Bot [bot] and 14 guests
