H801 rgbw plugin install
I read post but not understand how to get work this rgbww controller.I know how to upload firmware but what need upload ?
Some Raspeberry Pi's, Arduinos, Esp8266, solar panels 1500w, 2 lakes,6 ha fields, German shepherd and more
Re: H801 rgbw plugin install
You need to compile your own firmware since this plugin is not official. Download the INO file here: https://github.com/letscontrolit/ESPEas ... 5_RGBW.ino
I download all plugins and put these to Arduino folder. I upload to h801 EspEasy r120 512kb version. Working good and connected to my home network.
I have this plugin P105 rgbw. What is next ?
Since the plugin is not official you'll have to try and get a hold of the developer if you need further assistance.
I'm stuck at compiling the plugin into a new firmware. can anyone point how to put all the files into arduino ide please?
Hello parksy78,
It should work if you copy the plugin .ino file into the same directory containing all the ESPeasy files. Depending on the version of ESPEasy you are using (if it is one of the version 2.0.0 releases) you may need to select the Development version in the main ESPEasy.ino file. Then compile.
Hope this helps.
Andrew
Hope this helps.
Andrew
Can anybody upload this compiled firmware to.... Google drive and share it.
hei girls ???
