Did I fry my Sonoff
aussieatlarge
Did I fry my Sonoff
#1 Post by aussieatlarge » 25 Aug 2017, 06:06
I read that many people are experiencing issues with the latest batch of SONOFF switches. I am experiencing same issues - flash eventually takes but no activity on reboot.- no led, no wifi
However, I know that at one stage I tried flashing with 5v instead of 3v. The upload seems to work but thereafter issues described above. If it were fried, would anything work? How does one test?
LisaM
Re: Did I fry my Sonoff
#2 Post by LisaM » 25 Aug 2017, 13:27
aussieatlarge wrote: 25 Aug 2017, 06:06 I read that many people are experiencing issues with the latest batch of SONOFF switches. I am experiencing same issues - flash eventually takes but no activity on reboot.- no led, no wifi
https://ba0sh1.com/blog/2016/08/03/is-e ... -tolerant/
Meaning: possible, but unlikely...
Use Arduino IDE and monitor the serial after reboot...
BerndJ
#3 Post by BerndJ » 25 Aug 2017, 14:02
they changed the used Flash, see
viewtopic.php?f=5&t=3386&p=18046&hilit=DOUT#p18046
use DOUT and everything go fine.
best wishes
BerndJ
aussieatlarge
#4 Post by aussieatlarge » 25 Aug 2017, 15:10
Thanks but I have no idea what "use DOUT " means. The rest of the thread seems tonindicate one should use different firmware. Please help. I have3 dead SONOFFs
#5 Post by Shardan » 25 Aug 2017, 17:37
Which sonoff's are you using? Basic? 4CH?
A bit difficult to say which version you need.
BerndJ
#6 Post by BerndJ » 25 Aug 2017, 18:35
aussieatlarge wrote: 25 Aug 2017, 15:10.. "use DOUT "...
I´m using the Arduino IDE and thats the way to program the flash.
#7 Post by Shardan » 25 Aug 2017, 19:21
This "Flash Mode" field is not there with "generic ESP8285" sadly.
So it won't work for a Sonoff 4CH if we run into same problem.
A way out might be using the nodeMCU flasher
https://github.com/nodemcu/nodemcu-flasher
If i find time i'll make some screenshots and text and put it into the wiki.
aussieatlarge
#8 Post by aussieatlarge » 26 Aug 2017, 06:54
Single channel
Image of chip attached
#9 Post by Shardan » 26 Aug 2017, 15:09
It's a ESP8266 so it should be possible to use the Arduino IDE to upload in DOUT mode.
Install the Arduino IDE as described at https://letscontrolit.com/wiki/index.ph ... are_Upload
The instructions are still on R120 version, but setting up for ESPMega 2.0.0 is the same, just download the sources for ESPMega
from github instead the older versions.
Chose "Generic ESP8266" as board type, 1M Memory with 128K SPIFFS". set "Flash Mode" to "DOUT"
aussieatlarge
#10 Post by aussieatlarge » 31 Aug 2017, 06:12
Tried all of the above. I can upload but I do not get anything on the serial interface or a SSID.
I have tried 120 and 2.0
Meet_AU
#11 Post by Meet_AU » 31 Aug 2017, 08:58
I have exactly the same problem
Sonos single relay, brand new (arrived today)
I loaded the firmware. restarted and nothing happens
I used R120 and only ever supplied 3.3v
arnoldg
#12 Post by arnoldg » 31 Aug 2017, 10:14
had the exact seem problem.
I found this topic and did flash succesfull my sonoff basic.
viewtopic.php?f=5&t=3386&hilit=DOUT&start=10#p18240
Meet_AU
#13 Post by Meet_AU » 01 Sep 2017, 01:27
looks like the solved my problem
Users browsing this forum: Anthropic Claude Bot [bot] and 10 guests
