Using Milliseconds in Rules.
rmhoutz
#1 Post by rmhoutz » 08 Sep 2017, 14:29
Objective is to use a relay to do the same thing as the push button in my garage. To do that I just need the relay to turn on then off again for about 500 milliseconds. I've worked out how to use a timer in the rules to turn the relay off after a second but I really don't need it on for a full second. Is it possible to use milliseconds in the rules?
I have openHAB2 sending a MQTT to the ESP and the rule I set below to turn the switch off.
Any help or advice would be great.
on Garage_Door#ON do
 gpio,5,1
 timerSet,1,1
On Rules#Timer=1 do
 gpio,5,0
bfabien
Re: Using Milliseconds in Rules.
#2 Post by bfabien » 08 Sep 2017, 14:55
You have the pulse command for that
https://www.letscontrolit.com/wiki/inde ... ort_pulses
I've used it for a remote controller, and it works quite well!
rmhoutz
#3 Post by rmhoutz » 08 Sep 2017, 16:54
bfabien wrote: 08 Sep 2017, 14:55 You have the pulse command for that
:D Hi bfabien
Thank you so much, I figured it had to be something simple but I'm just getting started using ESP Easy and didn't know the pulse command was an option.
Funny enough I did see the GPIO command for simple on off and am using it on outlet switches I guess I just stopped reading that page after I figured out how to control the relay.
Thanks again you have no idea how much this helps.
TommySharp
#4 Post by TommySharp » 30 Apr 2018, 11:29
@rmhoutz
Could you share your final solution for your garage door and the momentary button press?
#5 Post by grovkillen » 30 Apr 2018, 13:58
