ESPEasy v2.0.0-dev12 released
psy0rz
#1 Post by psy0rz » 22 Sep 2017, 01:38
After a brief pause, i'm back, and we've released v2.0.0-dev12: https://github.com/letscontrolit/ESPEas ... .0.0-dev12
From this point forward the 2.0.0 merge window is closed. This means only bugfixes will go into 2.0.0: All the other pull requests will be postponed to 2.1.0.
From now on I will focus only on fixing bugs for 2.0.0 and working towards a beta release of version 2.0.0.
A current list with bugs that need to be fixed before a 2.0.0 release can be found here: https://github.com/letscontrolit/ESPEasy/milestone/1
Theoretically its possible to create a separate 2.0.0 development branch so that we also can continue merging pull requests for 2.1.0 in the mega-branch, but we do not have enough resources for this. So instead, i'll only merge fixes and leave the other pull requests open for 2.1.0.
There's an extensive list of issues on github (https://github.com/letscontrolit/ESPEasy/issues): If you spot a 2.0.0 issue that doesnt have the correct milestone yet, leave a comment on github.
Edwin
toffel969
Re: ESPEasy v2.0.0-dev12 released
#2 Post by toffel969 » 22 Sep 2017, 08:17
Thanks for all your hard work
#3 Post by grovkillen » 22 Sep 2017, 08:19
Great work everyone involved!
papperone
#4 Post by papperone » 22 Sep 2017, 08:40
thanks! will install it immediately on my test modules to provide feedback on stability :)
AndrewJ
#5 Post by AndrewJ » 22 Sep 2017, 09:49
Thanks to all who have worked hard to get this ready for release! A major milestone! 😁
papperone
#6 Post by papperone » 22 Sep 2017, 13:02
Just a small though on size and efficiency...
I agree that some plugins are too specific and should be flagged as such and not included in the standard firmware (like it happened with "_P070_NeoPixel_Clock.ino").
But looking at the current supported devices by the standard 2.0.0.dev12 I think there are below plugins which are the same if not less generic than the one above like "_P041_NeoClock.ino" which shoudl be flagged the same way to make sure the "core" set of plugins is quite generic, including general available sensors/devices rather than very specific ones.
It's only my 2cents as this is my personal view of how I see ESPEasy core modules...
#7 Post by Shardan » 22 Sep 2017, 13:07
Agree with papperone.
Good job guys.
ManS-H
#8 Post by ManS-H » 22 Sep 2017, 16:42
Good job Edwin, thanks.
Martinus
#9 Post by Martinus » 23 Sep 2017, 14:43
Just noticed that the IR plugin is missing from the default set of plugins.
Seems to be the only plugin with this condition:
#ifdef PLUGIN_BUILD_NORMAL
and it's not set true in the main file.
Was there a reason to disable this plugin (it has been in the default set for a long time..)
psy0rz
#10 Post by psy0rz » 23 Sep 2017, 14:47
papperone wrote: 22 Sep 2017, 13:02 Just a small though on size and efficiency...
yes i agree. i only started doing this recently because the number of plugins seems to be skyrocketting. :) maybe we should disable more plugins that are too specific.
psy0rz
#11 Post by psy0rz » 23 Sep 2017, 14:47
Martinus wrote: 23 Sep 2017, 14:43 Just noticed that the IR plugin is missing from the default set of plugins.
nope this is a bug. i'll look into it. "normal" plugins should be always compiled.
mrwee
#12 Post by mrwee » 26 Sep 2017, 16:03
Having flashed an Sonoff S20 from scratch, I encounter
Error while reading/writing config.dat in 926
in the weblog. I've gone over the config again and again but cannot see anything wrong. How can I find the config.dat data structure to locate the problem?
#13 Post by TD-er » 27 Sep 2017, 23:01
psy0rz wrote: 23 Sep 2017, 14:47
Or perhaps merge similar plugins, like the Bosch BMx280 temperature sensors (a pull request I already made).
Another thing that is somewhat bothering me, is the webserver "plugin", which is handling strings in memory of up to 10 kByte. That's heap fragmentation waiting to happen.
psy0rz
#14 Post by psy0rz » 28 Sep 2017, 00:07
fixed in commit 20b95c4
psy0rz
#15 Post by psy0rz » 28 Sep 2017, 00:08
mrwee wrote: 26 Sep 2017, 16:03 Having flashed an Sonoff S20 from scratch, I encounter
which firmware did you use exactly?
mrwee
#16 Post by mrwee » 28 Sep 2017, 09:10
psy0rz wrote: 28 Sep 2017, 00:08
I'm using 'ESPEasy_v2.0.0-dev12_normal_1024.bin' flashed with an FTDI adapter & 'FlashESP8266.exe'.
#17 Post by grovkillen » 28 Sep 2017, 10:48
mrwee wrote: 28 Sep 2017, 09:10 I'm using 'ESPEasy_v2.0.0-dev12_normal_1024.bin' flashed with an FTDI adapter & 'FlashESP8266.exe'.
Is the programmer a original FTDI one or a copy? The newer drivers are making clones/copies garbaging the flash even though it says "ok".
#18 Post by TD-er » 28 Sep 2017, 11:01
grovkillen wrote: 28 Sep 2017, 10:48
What version of the drivers are causing this? And what version is still working?
Or is it once being used with newer drivers, the clones are defective forever?
mrwee
#19 Post by mrwee » 28 Sep 2017, 12:34
Good question. How do I tell? I've programmed ~20 ESP's (Sonoff Basic, POW, TH10/TH16, H801) with this programmer and the S20 with v2.0.0-dev12 works fine besides this error message (I've flashed 3 x S20 with 2.0.0-dev12, they all behave this way).
I've fiddled around with different settings, and if I e.g. remove a very simple rule, then it sometimes stops with this error. An S20 with early v2 espeasy does not have this problem, so my assumption is that it's something introduced with dev12.
#20 Post by grovkillen » 28 Sep 2017, 14:01
Regarding drivers, I'm not sure since I have only used official FTDI (got them at work). But I would say the last year. I believe that they alter the FW in the clone as well (don't quote me on that one though).
How do you tell if you have a clone or not? Simple, what price you pay? Less than $15 or so and you'll have bought a clone. I don't think many genuine FTDI is sold through AliExpress or Ebay.
If you have been able to flash an earlier FW version (dev7 or so) and got it working correct you might want to try the OTA FW update to bump that without the use of a programmer... just as an test?
mrwee
#21 Post by mrwee » 28 Sep 2017, 20:27
Well. After playing around this evening I've found:
1) Tried with another flasher (Silicon Labs CP210x USB to UART Bridge). Same result for 2.0.0-dev12 as with the FTDI adapter.
2) Tried to downgrade to 2.0.0-dev11 OTA. Flashing failed.
3) Using flasher, I loaded 2.0.0-dev11 onto one S20 and did the same config as I had before. I could not provoke it to fail.
4) Tried OTA upgrade to 2.0.0-dev12. Flashing failed.
Guess I'll just stay with dev11 for now. Let me know if I can be of any assistance in troubleshooting the problem.
#22 Post by Shardan » 28 Sep 2017, 22:06
OTA on a 1MBit ESP-01 will always fail!
The existing ESPEasy-2.0.0-dev11 and the new 2.0.0-dev12 added together is more then 1024KB.
As OTA has to download the binary completely befor it starts flashing there's just not enough memory for that.
See https://letscontrolit.com/wiki/index.php/ESPEasy the "2.0+ firmware on 1MB modules" chapter.
mrwee
#23 Post by mrwee » 29 Sep 2017, 09:39
Shardan wrote: 28 Sep 2017, 22:06 OTA on a 1MBit ESP-01 will always fail!
ok. That I should have spotted. Sorry for that. I (now) understand the OTA restrictions, but both should be able to flash from scratch on a 1MB module?
ensingg
#24 Post by ensingg » 29 Sep 2017, 11:34
I've read about a new feature for uploading files in dev12.
Can someone tell me how it works?
#25 Post by Shardan » 29 Sep 2017, 13:04
mrwee wrote: 29 Sep 2017, 09:39 ok. That I should have spotted. Sorry for that. I (now) understand the OTA restrictions, but both should be able to flash from scratch on a 1MB module?
The 1024-Binaries should definitely work on a 1MB module.
Be aware there are some ESP-01 (V3) modules that might cause trouble due to changed pinouts.
If i remember right this was mentioned somewhere in the forum already.
I'll see if i can test the 1024 binariy on ESP-01 this weekend
mrwee
#26 Post by mrwee » 29 Sep 2017, 13:10
Shardan wrote: 29 Sep 2017, 13:04
ok, so 2.0.0-dev12 should work on an Sonoff S20? Then I think something happened between dev11 and dev12, causing this issue.
LisaM
#27 Post by LisaM » 29 Sep 2017, 13:17
ensingg wrote: 29 Sep 2017, 11:34 I've read about a new feature for uploading files in dev12.
Where did you see that :?:
ensingg
#28 Post by ensingg » 29 Sep 2017, 13:20
SightofSilence (1):
Add files via upload (#493)
#29 Post by Shardan » 29 Sep 2017, 13:28
I don't have S20 at hand so i can't test atm.
If i find some time this weekend i'll test with ESP-01 and possibly a Sonoff basic which is technically equivalent to the S20
LisaM
#30 Post by LisaM » 29 Sep 2017, 14:48
ensingg wrote: 29 Sep 2017, 13:20 https://github.com/letscontrolit/ESPEas ... .0.0-dev12
SightofSilence (1):
I see no such thing as upload... https://github.com/letscontrolit/ESPEasy/pull/493
ensingg
#31 Post by ensingg » 29 Sep 2017, 14:53
I just types what you see on the first screen.
psy0rz
#32 Post by psy0rz » 04 Oct 2017, 17:12
LisaM wrote: 29 Sep 2017, 14:48
SightofSilence (1):
somebody used a wrong commit message, it should read 'Renamed and rearranged "Devices:" on info-page'.
no new upload features, however with tools->flash you can already upload stuff. :)
psy0rz
#33 Post by psy0rz » 04 Oct 2017, 17:13
Shardan wrote: 29 Sep 2017, 13:28 I don't have S20 at hand so i can't test atm.
shouldnt the ESP8285 version of the firmware be used for a sonof device?
psy0rz
#34 Post by psy0rz » 04 Oct 2017, 17:15
psy0rz wrote: 04 Oct 2017, 17:13
ah our awesome wiki says the 1mb normal version should be ok indeed. https://www.letscontrolit.com/wiki/inde ... P_Hardware :)
#35 Post by grovkillen » 04 Oct 2017, 17:54
psy0rz wrote: 04 Oct 2017, 17:15 ah our awesome wiki
:mrgreen:
papperone
#36 Post by papperone » 04 Oct 2017, 17:58
psy0rz wrote: 04 Oct 2017, 17:15ah our awesome wiki says the 1mb normal version should be ok indeed. https://www.letscontrolit.com/wiki/inde ... P_Hardware :)
I think the major issues is that recent Sonoff units (and apparently I've heard recent Wemos D1 mini unit as well) have a different flash chip and if the flash process is done in QIO mode (like we all have been doind so far) will end up in a non working module. The solution is to flash those modules in DIO mode; as well it seems that flashing in DIO mode will in theory free up 2 more GPIOs (9 and 10) but while 10 is reported to work perfectly, 9 is causing ESP8266 reboot (investigation lead to think it's due to some connection track to the flash no needed but still there in the PCB).
As well I've read other users reported that older Sonoff are behaving weird if flashed in DIO mode :o
Long story short, we should plan a new version of the flash tool that has the option to choose flash mode, either QIO or DIO.
mrwee
#37 Post by mrwee » 04 Oct 2017, 19:52
For my problem with the S20 I think the device is 'as-usual' as espeasy boots & works pretty normal. It seems like when I put configuration on the device, then the error occurs. But only with dev12, not dev11.
HansV
#38 Post by HansV » 31 Oct 2017, 12:57
As far as I can see TaskValueSet randomly triggers a reboot condition.
I am running dev-12 (4Mb version) on a NodeMCU. Directly after a reboot I initiate a default value (using rule 1).
On System#Boot do
 TaskValueSet 3,1,0 // Zet de 1e param van dummy task #3 op 0
As far as I can see this is always the trigger for the message "FS : Error while reading/writing config.dat in 926".
Then the device will either reboot directly again, or will keep working for a random time (the highest number I have seen in uptime is 736).
Oct 28 14:01:22 ESP Unit: 1 : WD   : Uptime 288 ConnectFailures 0 FreeMem 18944
Oct 28 14:01:52 ESP Unit: 1 : WD   : Uptime 288 ConnectFailures 0 FreeMem 18968
Oct 28 14:02:15 ESP Unit: 1 : DS   : Temperature: 31.62 (28-ff-f1-f8-80-17-5-91)
Oct 28 14:02:15 ESP Unit: 1 : EVENT: CV-In#Temperature-In=31.62
Oct 28 14:02:15 ESP Unit: 1 : ACT  : event InlaatTemperatuurOK
Oct 28 14:02:15 ESP Unit: 1 : EVENT: inlaattemperatuurok
Oct 28 14:02:15 ESP Unit: 1 : ACT  : event PompKanAan
Oct 28 14:02:15 ESP Unit: 1 : EVENT: pompkanaan
Oct 28 14:02:15 ESP Unit: 1 : ACT  : TaskValueSet 3,1,1
Oct 28 14:02:30 ESP Unit: 1 : WIFI : Connected! IP: 192.168.11.153 (Nodemcu-CV-ketel_1)
Oct 28 14:02:31 ESP Unit: 1 : EVENT: System#Boot
Oct 28 14:02:31 ESP Unit: 1 : ACT  : TaskValueSet 3,1,0
Oct 28 14:02:31 ESP Unit: 1 : FS   : Error while reading/writing config.dat in 926
Oct 28 14:02:31 ESP Unit: 1 : WD   : Uptime 0 ConnectFailures 0 FreeMem 19032
Each reboot takes place directly after executing a TaskValueSet command
Some more info:
- The device that is giving the problems:
* new nodeMCU, flashed with ESPEasy v2.0.0-dev12
* 2 x DS18b20
* 700 mAh poweradapter
I have currently 10 ESPEasy devices active (4 x NodeMCU, 4 x Sonoff S20, 1 x Wemos D1, 1 x Sonoff Basic), all running ESPEasy v2.0.0-dev12.
Only the device running a task that executes TaskValueSet does randomly reboot, all others are very stable.
Any hints to solve this?
mrwee wrote: 26 Sep 2017, 16:03 Having flashed an Sonoff S20 from scratch, I encounter in the weblog. I've gone over the config again and again but cannot see anything wrong. How can I find the config.dat data structure to locate the problem?
mrwee
#39 Post by mrwee » 02 Nov 2017, 20:41
HansV wrote: 31 Oct 2017, 12:57 As far as I can see TaskValueSet randomly triggers a reboot condition.
On System#Boot do
Some more info:
* 2 x DS18b20
I'm getting the "Error while reading/writing config.dat in 926" with just:
on onoff#push=1 do
if [relay#Switch]=1
gpio,12,0
gpio,12,1
in my rules :(. See it on different devices.
kociubin
#40 Post by kociubin » 13 Nov 2017, 04:15
on onoff#push=1 do
if [relay#Switch]=1
gpio,12,0
gpio,12,1
Same here. Getting ""Error while reading/writing config.dat" for every rule that has an if statement. I'm running a bunch for Wemos D1's and ESP-12's.
#41 Post by grovkillen » 13 Nov 2017, 12:26
Please report on GitHub.
vader
#42 Post by vader » 13 Nov 2017, 19:04
Had the same. Just make a reset and config the ESP from scratch (no config restore to be sure!). After that:
Rule:
on Button#State do
if [Button#State]=1
event switchon
event switchoff
[Submit]
Log:
197926 : FILE : Saved config.dat
197951 : FILE : Saved security.dat
:D
#43 Post by Shardan » 13 Nov 2017, 19:59
I've configured a "blank" ESP-12E for my dust sensor prototype with 2.0.0-DEV12 TESTING, sources Oct.25. '17.
No issues even with a lot of rules.
mrwee
#44 Post by mrwee » 13 Nov 2017, 21:16
I'm able to reproduce this across different ESP8266 based products: Sonoff Basic, Sonoff S20, Sonoff TH16 & Wemos D1 mini pro.
My settings are:
- Various names for the device, e.g. "Garden light east"
- Different Unit ID's (e.g. 95, 128, 136)
- Static IP address
- OpenHAB MQTT with IP address
- NTP server set to IP addess
- Two devices configured: Button & Relay GPIO's
To me it seems like when the rule(s) become too long, the error occurs. I cannot reproduce at all with dev11.
Edit: Most tests have been performed with freshly flashed devices. Have also tried the 'reset' command, and starting all-over. Same result.
mrwee
#45 Post by mrwee » 14 Nov 2017, 22:23
This rule:
On System#Boot do //When the ESP boots, do
publish %sysname%/sysname,%sysname%
publish %sysname%/IP,%ip%
publish %sysname%/relay/Switch,[relay#Switch]
timerSet,1,60 //Set Timer 1 for the next event in 30 seconds
On Rules#Timer=1 do //When Timer1 expires, do
timerSet,1,60 //Resets the Timer 1 for another 30 seconds
results in the 'FS : Error while reading/writing config.dat in 926" error on one Sonoff TH10, but not on another TH10. Settings are identical (besides the obvious IP, device ID etc.).
If I change it to:
then it works.
If I change it to:
on onoff#push=1 do
if [relay#Switch]=1
gpio,12,0
gpio,12,1
I get the error on the same module, but not the other.
If I change it to:
on onoff#push=1 do
then no error.
Seems to me, that it could be related to the size of the rule.
