When I use mqtt to send infrared remote control instructions, but I don't know how to set up topic
I set it up like this, it didn't work:
mosquitto_pub -t /%sysname%/%taskname% -m'code'
Has anyone ever had the same problem?
how to Send command using MQTT broker service
Re: how to Send command using MQTT broker service
Have you studied the wiki?
A space is missing after -m! And a host name with -h would be nice....plutosherry wrote: ↑16 Oct 2017, 11:00 When I use mqtt to send infrared remote control instructions, but I don't know how to set up topic
Use mosquitto_pub --help for a list of all commands.
Thanks alots for u reply
I have been studied the wiki ,and i am also add space between the -m 'code'.
but it isn't work .... I suspect it's topic's problem
if i typed the topic like below:
sudo mosquitto_pub -t /espeasy/irsend/irtrans -m '2155855935'
the terminal appeared
IRTX :IR Code Sent
it's that all ?!
IRTX :IR Code Sent
it's that all ?!
What else should the terminal report? Maybe there ist a bit more in the log (Tools -> Log). Under Tools -> Advanced set the web log Level to 3 and check it out what it reports (I have no IR-module in use...)
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], OpenAI GPTBot [bot] and 1 guest
