I have v2.0.0 dev12 running on a Adafruit Feather. Task 1 is setup for a switch input on GPIO-13 with switch button type set to normal switch. I have a MQTT controller enabled and can see the published result on Node Red. But MQTT is publishing at the Delay rate set for the input.
What do I change so that the input status is only published when the switch status changes?
MQTT Publish Only On Input Change
Re: MQTT Publish Only On Input Change
set Delay=0prairietech wrote: ↑21 Oct 2017, 00:07 I have v2.0.0 dev12 running on a Adafruit Feather. Task 1 is setup for a switch input on GPIO-13 with switch button type set to normal switch. I have a MQTT controller enabled and can see the published result on Node Red. But MQTT is publishing at the Delay rate set for the input.
Wow! That was easy! I've got to stop complicating the easy things.enesbcs wrote: ↑21 Oct 2017, 07:18set Delay=0prairietech wrote: ↑21 Oct 2017, 00:07 I have v2.0.0 dev12 running on a Adafruit Feather. Task 1 is setup for a switch input on GPIO-13 with switch button type set to normal switch. I have a MQTT controller enabled and can see the published result on Node Red. But MQTT is publishing at the Delay rate set for the input.
