Phantom Yoyo light sensor
trumee
#1 Post by trumee » 21 Oct 2017, 17:31
I have a phantom yoyo light sensor, please can somebody let me know which device should i pick in ESP Easy?
I have connected its signal pin to the AD pin of Node MCU.
Re: Phantom Yoyo light sensor
#2 Post by Shardan » 21 Oct 2017, 18:58
The analog input of the nodeMCU is correct.
In the device settings chose "Analog input".
Please keep in mind that this sensor doos ot give a digital value like "xxx Lux".
It gives a voltage that is equivalent to the luminosity so you will have to use a formula
to "translate" the value into a lux value.
The more this sensor can not give "0" for "no light" due to technical reasons.
This can be compensated with the formula too.
For calibration see wiki: https://www.letscontrolit.com/wiki/inde ... d_Accuracy
Fur using formulas see wiki https://www.letscontrolit.com/wiki/inde ... asyFormula
Users browsing this forum: Anthropic Claude Bot [bot] and 13 guests
