VOC sensor MiCS 5524
karl222
#1 Post by karl222 » 25 Oct 2017, 19:28
hi there,
does anyone have an idea how to integrate this VOC sensor. it has an i2c interface. it seems obvious that it needs some re-coding but in general should be doable due to i2c interface.
her is the datasheet https://cdn-shop.adafruit.com/product-f ... S-5524.pdf
it sells for just USD 6,80 on ebay.
help is appreciated, since i do have no programming skills ;-)
regards and thanks
karl
karl222
Re: VOC sensor MiCS 5524
#2 Post by karl222 » 30 Oct 2017, 13:36
hey guys,
After digging a bit deeper I found the solution. the sensor itself has i2c but the breakout module delivers analog signal which can be processed by an ADC. this is fine!
Curious, I only get values between 10 and 30 on an esp ADC, which translates to 0,01 to 0,03V with 1024 Digits (10bit) and max 1V Input on the ESP. this is something I don't really believe...
does someone have an idea on that?
regards
karl
