text to lcd2004 (espeasy)
Posted: 28 Oct 2017, 19:07
by adval40
I will send text from domoticz to a lcd2004 on an espeasy board
commandArray = {}
commandArray['OpenURL'] = '192.168.0.144/control?cmd=lcd,3,1,ditiseentest'
print ('test ')
return commandArray
it works but in the logfile i see
2017-10-28 19:03:30.280 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.237 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.311 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.382 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.694 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
2017-10-28 19:03:31.925 Error: Error opening url: 192.168.0.144/control?cmd=lcd,3,1,ditiseentest
whats wrong in my lua script
thanks in advance
Ad
Re: text to lcd2004 (espeasy)
Posted: 30 Oct 2017, 08:54
by toffel969
Posted: 30 Oct 2017, 11:32
by adval40
you mean this ?
commandArray['OpenURL'] = "
http://192.168.0.144/control?cmd=lcd,3,1,ditiseentest"
print ('test ')
return commandArray
this gives the same error ...
Posted: 20 Nov 2017, 18:31
by adval40
Hello ,
I have tried a lot
this is a lua script
I want to send data tot a lcd2004 display
It works but an error in the log file
who can give me the solution ?
Ad
Posted: 20 Nov 2017, 19:30
by TD-er
Remove "control" between / and ?
Like this
http://192.168.0.144/?cmd=lcd,3,1,test
Posted: 20 Nov 2017, 20:41
by adval40
no then you came into de espeasy
Posted: 20 Nov 2017, 22:32
by grovkillen
The URL is fine.
http://192.168.0.144/control?cmd=lcd,3,1,test
But back to the OP, where do you see this error? On the ESP or the Lua executor?
Posted: 20 Nov 2017, 23:10
by adval40
the error is on the log from domoticz
print ('test ')
return commandArray
the display is connected to a esp12 with espeasy
Ad
Posted: 21 Nov 2017, 05:52
by grovkillen
So is this Domoticz related then or what? The URL does update the display but Domoticz is throwing an error? Is any other commands that is sent from Domoticz to ESP Easy working but giving error in the Domoticz log?
Posted: 22 Nov 2017, 14:06
by henkdejonge
Hi regarding this issue i'm facing the same errors. It doesn't make any difference if I make a lua script via the time script method I'll get the same error message.
There is also a strange issue if I try to display something on line 4 it's displayed on line 2.
I'm using a 4 x 20 lines display.
The display is connected to a esp12e with the latest ESPeasy v2.0.0-dev12. Domoticz is running on the latest stable version 3.8153.
2017-11-22 14:01:00.262 LUA: Pinging Henk
2017-11-22 14:01:00.379 LUA: Henk thuis
2017-11-22 14:01:00.382 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_ping_henk.lua
2017-11-22 14:01:00.409 LUA: Pinging Ursula
2017-11-22 14:01:00.443 (Ping) Light/Switch (Henk)
2017-11-22 14:01:01.457 LUA: Ursula niet thuis
2017-11-22 14:01:01.460 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_ping_urs.lua
2017-11-22 14:01:01.477 LUA: test
2017-11-22 14:01:01.477 EventSystem: Fetching url...
2017-11-22 14:01:01.477 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_display.lua
2017-11-22 14:01:01.525 (Ping) Light/Switch (Ursula)
2017-11-22 14:01:01.754 Error: Error opening url: 10.0.0.61/control?cmd=lcd,1,1,Domoticz_Sportweg
Henk.
