Push Button state not synced
hchris
#1 Post by hchris » 11 Nov 2017, 16:03
Hello everyone,
I'm completely new to world of IoT so it could be the case that my question has been asked a couple of times. However, I didn't manage to find a working answer.
I have a Raspberry Pi running Openhab2 and an ESP with ESPEasy. For Testing I connected a Button to the ESP. It works perfectly and I can see that it is toggling on the Openhab Web interface.
Unfortunately pressing the switch on the web interface causes trouble. When I press the button connected to the ESP again, it won't toggle the first time (It sends a 1 or 0 but the value has changed before by the Openhab UI).
I had the idea to trigger an event everytime you press the switch on the web interface so that the ESP thinks it gets pressed.
I found a method called inputswitchstate but it didn't have any effect.
Anyone who solved the problem?
Thanks in advance and sorry if the description is not precise enough :)
vader
Re: Push Button state not synced
#2 Post by vader » 11 Nov 2017, 18:04
Screen shots of your config, a log and the rules would be helpful to know....
#3 Post by grovkillen » 11 Nov 2017, 21:15
I suspect that you try to "press" the button through HTTP but this is not the way you do stuff like that. You would make an event in rules. An event is possible to trigger using pretty much anything. By pressing a button, sending a command through HTTP, the time of day .,.. etc.
But to know what you intend to do you need to give us more information. A set of screenshots is a good start, as Vader already suggested.
