ESP Easy rule to enable button
PizzaChip
#1 Post by PizzaChip » 06 Dec 2017, 17:47
In the past someone posted a rule to enable the switching ON/OFF by pressing the button on Sonoff 10A but for some reason the rule partially works meaning that it turns on the light but then it automatically turns it off after some seconds and I do not understand why....
in ESP EASY v 12 I have the following devices:
LightSwitch is configured as:
Rule is:
on lightSwitch#Switch do
if [lightState#Switch]=0
gpio,12,1
gpio,12,0
Why does it automatically turn off I really have no clue...
Re: ESP Easy rule to enable button
#2 Post by grovkillen » 06 Dec 2017, 19:11
You shouldn't use "normal switch" mode. Use one of the active high/low.
PizzaChip
#3 Post by PizzaChip » 06 Dec 2017, 20:32
I tried both and didn't make a difference
vader
#4 Post by vader » 06 Dec 2017, 20:33
That can not work. Try this...
if [lightSwitch#Switch]=0
gpio,12,0
gpio,12,1
PizzaChip
#5 Post by PizzaChip » 06 Dec 2017, 21:42
I see what you did there and I get it, but still it doesn't work.. :cry:
vader
#6 Post by vader » 06 Dec 2017, 21:47
Can you post all rules and some screenshots of your config?
PizzaChip
#7 Post by PizzaChip » 06 Dec 2017, 21:58
There is only one rule and is the one posted above, config screenshots are the ones above
PizzaChip
#8 Post by PizzaChip » 06 Dec 2017, 22:07
The button works, it stays on for approx 5 seconds and then it automatically turns off :cry: :oops:
vader
#9 Post by vader » 07 Dec 2017, 08:58
Where do you see screenshots above? Have you checked the log, if there is something to see what the reason could be?
danmero
#10 Post by danmero » 07 Dec 2017, 12:55
PizzaChip wrote: 06 Dec 2017, 17:47 Rule is:
gpio,12,1
gpio,12,0
You want to use a momentary switch to toggle a gpio
Try this
		event myevent
on myevent do
		gpio,12,1
		gpio,12,0
or
		event myevent
on myevent do
		TaskValueSet 2,1
		TaskValueSet 2,0
or
On lightSwitch#Switch do
		event MyEvent
	Endif
On MyEvent do
		InputSwitchState 1,1
		InputSwitchState 1,0
Regards,
vader
#11 Post by vader » 07 Dec 2017, 13:23
@danmero: Where is the point that helps him and that we not already posted/suggested above?
BTW: TaskValueSet needs 3 values, not 2!
PizzaChip
#12 Post by PizzaChip » 07 Dec 2017, 15:21
I tried using the event and it behaves the same, it turns on and stays on for some 5/6 seconds and then turns off
PizzaChip
#13 Post by PizzaChip » 07 Dec 2017, 15:24
vader wrote: 07 Dec 2017, 08:58 Where do you see screenshots above? Have you checked the log, if there is something to see what the reason could be?
DEVICES
LIGHTSWITCH
RULE
gpio,12,1
gpio,12,0
Users browsing this forum: Anthropic Claude Bot [bot] and 23 guests
