WS2812b, rules and temperature/humidity range
bogas
#1 Post by bogas » 21 Jan 2018, 19:15
Hey.
And this is my second problem, which I can not deal with :)
Is the following rule correct?
Currently, the orange LED is on and the humidity is around 35%.
In the device I chose neopixel basic.
On HTU#Humid do
if [HTU#Humid] > 40
neopixel,1,0,0,50
neopixel,1,50,50,50
On HTU#Humid do
if [HTU#Humid] > 45
neopixel,1,0,50,50
neopixel,1,0,0,50
On HTU#Humid do
if [HTU#Humid] > 50
neopixel,1,0,50,0
neopixel,1,0,50,50
On HTU#Humid do
if [HTU#Humid] > 55
neopixel,1,50,50,0
neopixel,1,0,50,0
On HTU#Humid do
if [HTU#Humid] > 60
neopixel,1,50,0,0
neopixel,1,50,50,0
Re: WS2812b, rules and temperature/humidity range
#2 Post by grovkillen » 21 Jan 2018, 21:19
This is what I do with three imported (mqtt import) RH values. If some of it is over a certain level change the neopixel:
On System#Boot do
TimerSet,1,10
EndOn
On Rules#Timer=1 do
TaskValueSet,1,1,0
If [import#rh1] < 30
TaskValueSet,1,1,1
EndIf
If [import#rh2] < 30
TaskValueSet,1,1,1
EndIf
If [import#rh3] < 30
TaskValueSet,1,1,1
EndIf
If [Evaluate#RH]=1
  NeoPixel,1,0,25,0 //red
Else
  NeoPixel,1,25,0,0 //green
EndIf
TimerSet,1,10
EndOn
So I use a dummy device to store values. And at the beginning of each run I set the value to zero and then evaluate it.
I hope I can inspire you to fix your rule.
toffel969
#3 Post by toffel969 » 22 Jan 2018, 19:46
Using the same event multiple times is not recommended.
viewtopic.php?f=6&t=2913&p=15179&hilit= ... ing#p15179
This way, you should be able to create rules that fulfil intended function
bogas
#4 Post by bogas » 28 Jan 2018, 11:23
Guys,
can You help with these colors?
toffel969
#5 Post by toffel969 » 29 Jan 2018, 05:47
bogas wrote: 28 Jan 2018, 11:23 Guys,
We are man, both grovkillen and my posts are containing the information and principles to fix the problem. what exactly do you expect? That we write your rules? Then (and that be sad enough) you gonna have to provide screenshots of the devices and some logs...
Users browsing this forum: Anthropic Claude Bot [bot], Bing [Bot] and 20 guests
