esp Build 53
vmfs1968
esp Build 53
#1 Post by vmfs1968 » 19 Dec 2015, 19:56
there are problems in version 53
lcd 20x4 does not work properly
puts it in at line 1
Painel Solar[painel#Temperatura#R] C
and looks like this
Painel+Solar%5Bpainel%23Temperatura%23R%5D+C
Martinus
Re: esp Build 53
#2 Post by Martinus » 20 Dec 2015, 09:26
I think you're not using ESP core 2.0.0. in Arduino IDE. Development releases only work with core 2.0.0.
Could you check this and confirm if it solves the issue?
My display is fine with R53
vmfs1968
Re: esp Build 53
#3 Post by vmfs1968 » 20 Dec 2015, 09:43
Martinus wrote:I think you're not using ESP core 2.0.0. in Arduino IDE. Development releases only work with core 2.0.0.
I'm using the core esp 2.0.0
R48 and R50 in the version works well
and r53 version gives this problem
Martinus
Re: esp Build 53
#4 Post by Martinus » 20 Dec 2015, 10:23
Can't reproduce the error here. This behavior should only occur if there's no URLdecode used.
We did this decoding ourselves until R51 and removed it in R52 because it is now handled in the ESP Core library as of 2.0.0.
Anyone else with this issue?
Maybe your compiler setup got mixed up somehow and still uses older libraries.
I'm using a fresh Arduino 1.6.5. portable setup with only ESP core 2.0.0 added to keep things clean. Would not be the first time that issues arise from multiple libraries, conflicting library paths, search order etc. We've seen more than once that rebuilding the IDE setup fixes strange problems.
vmfs1968
Re: esp Build 53
#5 Post by vmfs1968 » 20 Dec 2015, 10:42
let's see if I can explain it better
I on the lcd by exe:
meto this --- line1 Painel Solar[painel#Temperatura#R] C
when I click on SUBMIT
changes soon to this line1 Painel+Solar%5Bpainel%23Temperatura%23R%5D+C
I have a clean and portable INSTALLATION
Martinus
Re: esp Build 53
#6 Post by Martinus » 20 Dec 2015, 12:22
The only reason for these strange characters is a missing urlDecode function on formdata send back from your browser. Just double checked my ESP core library:
C:\Tools\arduino-1.6.5P200\Portable\packages\esp8266\hardware\esp8266\2.0.0\libraries\ESP8266WebServer\src\Parsing.cpp
In this file at line 267 there's the magic:
arg.value = urlDecode(data.substring(equal_sign_index + 1, next_arg_index));
it calls this function at line 517
String ESP8266WebServer::urlDecode(const String& text)
So I can't explain the missing translation for core 2.0.0. This feature was added at November 22nd and it's only available in stable 2.0.0.
Maybe there's confusion about core 2.0.0. as there are also staging rc (release candidates) available.
And I have checked and verified that this urldecode Is not available in 2.0.0-rc2.
If I upload the R53 using ESP core 2.0.0.-rc2, I can reproduce your errors with the older release candidate.
So could you please check once more that u have 2.0.0., so not 2.0.0-rc2.
Your IDE prefences should point to this url:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
vmfs1968
Re: esp Build 53
#7 Post by vmfs1968 » 20 Dec 2015, 13:25
you're right
I was using the RC version 2.02
to 2.0.0 everything is ok
thank you so much
long live the esp8266 and this forum
maluko
Re: esp Build 53
#8 Post by maluko » 20 Dec 2015, 14:59
I am trying put value by DHT11 on LCD and cant get.
T: [DHT11#Temperature] H:[DHT11#Humidity]
It appear only T: H:
Can you help
i am using R53
mkotek
Re: esp Build 53
#9 Post by mkotek » 20 Dec 2015, 16:39
maluko wrote:I am trying put value by DHT11 on LCD and cant get.
Can you help
i am using R53
Please note, DHT11 here means Task name and not the plugin. Is your Task for DHT11 sensor named exactly DHT11?
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
maluko
Re: esp Build 53
#10 Post by maluko » 20 Dec 2015, 17:51
Can you help
i am using R53
Sorry,my fault, its work now :)
thanks
