http requests and commands
riker1
#1 Post by riker1 » 28 Jan 2018, 15:11
is there an overview about available commands and http requests?
looking for command for switch or send text to serial via serial server plugin .
looks like this reference is not updated
https://www.letscontrolit.com/wiki/inde ... _Reference
Thanks T
Re: http requests and commands
#2 Post by grovkillen » 28 Jan 2018, 18:02
That list is the list of generic commands and is up to date.
The plugin specific commands is supposed to be in the plugin documentation. I have some job to do, not all these plugin pages are up to standard.
To be able to send serial data you have to use the command "serialsend".
For a switch you would use the gpio command but you might mean something else?
riker1
#3 Post by riker1 » 29 Jan 2018, 15:04
thanks for the explanation.
this does help.
I was referencing to the switch input switch a generic one not gpio related.
was wondering if there was a command to address a switch by name or so.
will try the serialsend command,
by the way, how to serial send hex? will it be control?cmd=serialsend,A0x01x01xA2 ?
I assume serialsend will send to serial server as device,
I am not quite clear about serial settings in tool tab
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 19 guests
