there is very much of plugin on the communication serie in easy esp.
after several tests, with a basic plug-in style p-020 Ser2Net and modification, I do not communicate with anything.
what wants to do is receive 2 bytes sent by an arduino to 19200 bauds, integrate them into 2 TaskDeviceValueNames [0] and [1], then return a byte to the arduino, or put a pin to 1 on esp to confirm the reception.
if you know how to use the serial port under easy esp, I'm at your listening,
because I dry a little to write my plugin, and the use under easy esp ets quite different from that of arduino.
Thank you for all your advice.....
