rtttl play on mqtt message?
rene9900
#1 Post by rene9900 » 07 Mar 2018, 23:29
im playing around with the PLUGIN_BUILD_TESTING version and made it play starwars theme when i push a button <3
thats awsome, i know :D
but i wanted to make a doorbell so the button is located on a esp8266 at the front door, and when pushed it send a mqtt topic so the unit
with the buzzer play the tune, but i can not wrap my head around it and figure out how to send the RTTTL command like that?
i tried
on systemboot do
rtttl,14:d=4,o=5,b=180:8f,8f,8f,2a#.,2f.6,8d#6,8d6,8c6,2a#.6,f.6,8d#6,8d6,8c6,2a#.6,f.6,8d#6,8d6,8d#6,2c6,p,8f,8f,8f,2a#.,2f.6,8d#6,8d6,8c6,2a#.6,f.6,8d#6,8d6,8c6,2a#.6,f.6,8d#6,8d6,8d#6,2c6
and it works, locally on the buzzer unit, but i still can't make it pickup a mqtt,
i also tried the http command and it play only a few beeps then it stops again
any ideas? :ugeek:
toffel969
Re: rtttl play on mqtt message?
#2 Post by toffel969 » 08 Mar 2018, 07:51
rene9900 wrote: 07 Mar 2018, 23:29 im playing around with the PLUGIN_BUILD_TESTING version and made it play starwars theme when i push a button <3
i tried
on systemboot do
any ideas? :ugeek:
Make an event in rules that contains the rttl sequence, then trigger that event by http/mqtt
On music do
Rttl,.........your sequence
To trigger
http://<espeasyip>/control?cmd=event,Music
Not sure if mqtt also works,
rene9900
#3 Post by rene9900 » 08 Mar 2018, 08:36
cool your rule works perfect, so does the trigger, then i just need to make another esp send a trigger when doorbell is pushed
i tried via node-red to "translate" a message to the http trigger, but it wont work.
seems odd to me if a rule cant be triggered by mqtt?
toffel969
#4 Post by toffel969 » 08 Mar 2018, 08:40
I don't use mqtt, and know little to nothing about it..
#5 Post by grovkillen » 08 Mar 2018, 09:14
How do you send the mqtt command? Please give us the topic and payload.
rene9900
#6 Post by rene9900 » 08 Mar 2018, 09:32
grovkillen wrote: 08 Mar 2018, 09:14 How do you send the mqtt command? Please give us the topic and payload.
i didnt because i couldnt make it work :lol:
i used toffels969's advice and
by a switch button and some rules, its HTTP cmd, i dont know if thats why it has like 1 sec delay on press??
//Doorbell
//Sender esp
On Switch#Switch=1 do
SendToHTTP 192.168.1.100,/control?cmd=event,Music
//Reciever ESP
On Music do
#7 Post by grovkillen » 08 Mar 2018, 10:05
I'm not asking for help. I want to help you. The syntax of mqtt cmd is this:
Topic
<MQTT subscribe template>/cmd
Payload
event,<eventName>
As stated here: https://www.letscontrolit.com/wiki/inde ... _Reference
Regarding the delay, what's your setting for "message delay" found in the advanced page? Default is 1000ms, but for devices with switch input its recommended to set this to 100ms.
rene9900
#8 Post by rene9900 » 08 Mar 2018, 10:14
I have set it to 250ms same delay, but its bearable 🤣
#9 Post by grovkillen » 08 Mar 2018, 10:16
NTP enabled but no host?
rene9900
#10 Post by rene9900 » 08 Mar 2018, 12:50
Yes i guess it use my router time server, only Way i could make time work was 60 and no server
Domosapiens
#11 Post by Domosapiens » 08 Mar 2018, 14:15
@Mr Wiki Grovkillen ;)
NTP Hostname Can be left empty as it defaults to pool.ntp.org. Can be changed here if needed.
https://www.letscontrolit.com/wiki/inde ... _interface
#12 Post by grovkillen » 08 Mar 2018, 14:26
Domosapiens wrote: 08 Mar 2018, 14:15 @Mr Wiki Grovkillen ;)
Aaah :lol: Thanks!
rene9900
#13 Post by rene9900 » 09 Mar 2018, 10:29
grovkillen wrote: 08 Mar 2018, 10:05 I'm not asking for help. I want to help you. The syntax of mqtt cmd is this:
Topic
Payload
event,<eventName>
i have been trying this template, but i dont understand it i guess :( how do i make a esp send a mqtt cmd on button press, and then make a second esp grab the command and then execute the rule set?
am i supposed to change anything in controller setup as it is now it listen for %sysname%# in subscripe which i guess is ok?
#14 Post by grovkillen » 09 Mar 2018, 10:56
You need to use rules and trigger "publish" on button unit.
Publish <name of second unit >/cmd,event,<eventName>
rene9900
#15 Post by rene9900 » 09 Mar 2018, 11:10
grovkillen wrote: 09 Mar 2018, 10:56 You need to use rules and trigger "publish" on button unit.
ah i get it...using mqtt spy to make sure its not the esp sender that makes a mess
log goes like this
MQTT : Topic: GUL/cmd
MQTT : Payload: event,Music
EVENT: Music
ACT : rtttl,14:d=4,o=5,b=180:8f,8f,8f,2a#.,2f.6,8d#6,8d6,8c6,2a#.6,f
i guess on sender esp the rule go like this?
Publish GUL/cmd,event,Music
i had a rule not disabled properly with 2 // but only 1 when i added the second / it worked, THANK YOU for once again saving my hair from beeing ripped out by its roots :D
#16 Post by grovkillen » 09 Mar 2018, 11:13
Happy to have helped. :)
And the rule you posted seems all right.
rene9900
#17 Post by rene9900 » 10 Mar 2018, 21:16
grovkillen wrote: 09 Mar 2018, 11:13 Happy to have helped. :)
one last question :)
how come when i reboot my unit it plays the tune in rules that only is supposed to play on either button press on the unit or by the remote sender unit?
my ruleset looks like this:
Publish ROSENQUIST/cmd,event,Music
gpio 12,1 //blå led
//delay 2000
gpio 12,0
On Music do
rtttl,14:d=4,o=5,b=180:8f,8f,8f,2a# //made shorter to avoid wife anger while testing :)
#18 Post by TD-er » 10 Mar 2018, 21:54
Maybe the pin value is somehow changed?
Either by booting (activating pull-up) or receiving the setting from an external source?
#19 Post by grovkillen » 10 Mar 2018, 22:18
Psy0rz told me the rtttl code is not stable at all. You can even get it in a endless loop as I describe here:
https://github.com/letscontrolit/ESPEasy/issues/446
I think we need to remove the hashtag (#) from the tune code, it might trigger some rules by mistake? I mean in the command execution internally and not in your tune.
Maybe use @ instead?
rene9900
#20 Post by rene9900 » 10 Mar 2018, 23:04
grovkillen wrote: 10 Mar 2018, 22:18 Psy0rz told me the rtttl code is not stable at all. You can even get it in a endless loop as I describe here:
so i should try change rtttl code replace # with @?
EDIT: if i reboot my PI that runs mosquitto server it also plays the tune
toffel969
#21 Post by toffel969 » 11 Mar 2018, 08:52
rene9900 wrote: 10 Mar 2018, 23:04
For curiosity, try to disable the mqtt retain flag under adavanced tab and see if it still behaves the same
#22 Post by grovkillen » 11 Mar 2018, 08:59
rene9900 wrote: 10 Mar 2018, 23:04 so i should try change rtttl code replace # with @?
No no, I'm talking about source code. You cannot do anything about it until rtttl is more stable.
rene9900
#23 Post by rene9900 » 12 Mar 2018, 08:44
i gotten rid of the play on reboot by changing the event,Music to event,Music#1
now i can reboot the mqtt server or it can lose wifi, and i can reboot my esp8266 safely.
#24 Post by grovkillen » 12 Mar 2018, 08:45
Now that is something to report to Github. Will you do it?
EDIT: I attached a link to this thread to the issue #446.
