Deep sleep triggers multiple MQTT publish
rutberg
#1 Post by rutberg » 27 Mar 2018, 08:42
Hi!
I've got a DHT22 and publish temp/humidity to a Home Assistant server via MQTT. I'm running the ESP_Easy_v2.0-20180322_test_ESP8266_4096_VCC firmware and i use a rule to also push VCC and IP to the MQTT server on MQTT Connection.
One issue I'm stuck at when enabling deep sleep is that the ESP doesn't publish one update then goes to sleep, instead, it publishes as many updates as it can, creating quite strange readings;
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:26:01.830
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:26:02.782
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:26:02.822
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:26:02.823
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:02.824
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:26:02.826
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:02.832
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:26:02.876
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:26:02.885
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:26:03.784
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:26:03.785
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:26:03.796
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:03.798
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:26:03.802
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:03.804
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:26:03.819
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:26:03.825
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.40	192.168.1.165	27/03 08:26:04.780
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:26:04.783
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40	192.168.1.165	27/03 08:26:04.785
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:04.790
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:26:04.813
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:04.814
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.40	192.168.1.165	27/03 08:26:04.823
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:26:04.830
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:26:05.780
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:26:05.787
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:26:05.788
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:05.790
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:26:05.792
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:05.795
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:26:05.807
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:26:05.813
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:26:06.789
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:26:06.796
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:26:06.804
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:06.808
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:26:06.813
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:06.816
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:26:06.824
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:26:06.835
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:26:07.780
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:26:07.781
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:26:07.784
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:07.810
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:26:07.811
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:07.813
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:26:07.820
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:26:07.827
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:26:08.784
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:26:08.786
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:26:08.787
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:08.789
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:26:08.790
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:08.792
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:26:08.824
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:26:08.835
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:26:09.780
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:26:09.786
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:26:09.788
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:09.790
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:26:09.793
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:09.795
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:26:09.824
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:26:09.839
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:26:10.780
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:26:10.784
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:26:10.785
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:26:10.788
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:26:10.789
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:26:10.795
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:26:10.808
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:26:10.814
<7>ESP_Easy EspEasy: WIFI : Connected! IP: 192.168.1.165 (ESP_Easy-1) AP: RobinMadde AP BSSID: 00:22:07:4B:9E:2B	192.168.1.165	27/03 08:35:32.234
<7>ESP_Easy EspEasy: EVENT: System#Boot	192.168.1.165	27/03 08:35:32.235
<7>ESP_Easy EspEasy: EVENT: System#Boot Processing time:5 milliSeconds	192.168.1.165	27/03 08:35:32.236
<7>ESP_Easy EspEasy: MQTT : Connected to broker with client ID: ESPClient_DC:4F:22:10:38:F0	192.168.1.165	27/03 08:35:32.267
<7>ESP_Easy EspEasy: Subscribed to: null	192.168.1.165	27/03 08:35:32.276
<7>ESP_Easy EspEasy: EVENT: MQTT#Connected	192.168.1.165	27/03 08:35:32.329
<7>ESP_Easy EspEasy: ACT  : Publish homeassistant/sensor/ESP_Easy/1/IP,192.168.1.165	192.168.1.165	27/03 08:35:32.342
<7>ESP_Easy EspEasy: ACT  : Publish homeassistant/sensor/ESP_Easy/1/VCC,2.80	192.168.1.165	27/03 08:35:32.364
<7>ESP_Easy EspEasy: EVENT: MQTT#Connected Processing time:63 milliSeconds	192.168.1.165	27/03 08:35:32.385
<7>ESP_Easy EspEasy: WD   : Uptime 0 ConnectFailures 0 FreeMem 16568	192.168.1.165	27/03 08:35:32.385
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:32.418
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:35:32.419
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:32.420
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:31 milliSeconds	192.168.1.165	27/03 08:35:32.445
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:35:32.445
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:32.446
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:32.473
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:35:32.478
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.80	192.168.1.165	27/03 08:35:33.416
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:33.420
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80	192.168.1.165	27/03 08:35:33.420
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:33.421
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:33.422
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:33.423
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.80	192.168.1.165	27/03 08:35:33.441
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:33.448
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.40	192.168.1.165	27/03 08:35:34.415
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.80	192.168.1.165	27/03 08:35:34.416
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40	192.168.1.165	27/03 08:35:34.417
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:34.418
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.80	192.168.1.165	27/03 08:35:34.419
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.80 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:34.420
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.40	192.168.1.165	27/03 08:35:34.440
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.80	192.168.1.165	27/03 08:35:34.445
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:35.427
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:35.428
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:35.429
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:35.430
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:35.431
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:35.432
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:35.442
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:35.450
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:35:36.416
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:36.416
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:35:36.417
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:36.418
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:36.420
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:36.420
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:35:36.450
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:36.455
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.80	192.168.1.165	27/03 08:35:37.418
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:37.427
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80	192.168.1.165	27/03 08:35:37.428
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:37.429
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:37.430
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:37.431
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.80	192.168.1.165	27/03 08:35:37.445
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:37.456
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:38.416
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:38.416
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:38.418
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:38.523
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:38.525
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:38.537
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:39.416
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:39.417
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:39.417
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:39.420
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:39.421
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:39.421
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:39.446
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:39.455
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:40.415
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:40.417
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:40.417
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:40.420
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:40.421
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:40.422
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:41.630
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:41.639
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:41.673
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:41.675
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:41.676
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:41.678
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:41.678
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:41.680
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:41.699
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:41.705
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:42.675
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:42.675
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:42.676
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:42.677
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:42.677
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:42.678
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:42.699
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:42.704
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:43.678
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:43.684
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:43.685
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:43.686
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:43.687
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:43.688
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:43.701
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:43.706
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:44.686
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:44.687
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:44.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:44.688
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:44.689
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:44.689
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:44.700
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:44.706
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:35:45.673
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:45.675
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:35:45.676
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:45.676
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:45.677
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:45.677
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:35:45.698
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:45.704
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:35:46.686
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:46.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:35:46.689
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:46.689
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:46.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:46.692
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:35:46.703
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:46.710
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:47.676
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:47.679
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:47.680
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:47.682
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:47.682
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:47.683
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:47.736
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:47.741
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:48.689
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:48.693
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:48.694
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:48.695
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:48.695
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:48.723
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:48.727
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:48.739
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.80	192.168.1.165	27/03 08:35:49.676
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:35:49.677
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80	192.168.1.165	27/03 08:35:49.678
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:49.678
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:35:49.681
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:49.681
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.80	192.168.1.165	27/03 08:35:49.701
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:35:49.707
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:50.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:50.683
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:50.684
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:50.684
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:50.686
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:50.687
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:50.704
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:50.709
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:35:51.687
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:35:51.689
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:35:51.690
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:51.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:35:51.692
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:51.693
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:35:51.710
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:35:51.715
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:52.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:52.679
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:52.682
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:52.683
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:52.685
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:52.685
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:52.711
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:52.715
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:35:53.687
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:53.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:35:53.689
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:53.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:53.692
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:53.693
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:35:53.702
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:53.717
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:54.676
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:54.676
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:54.677
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:54.679
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:54.679
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:54.681
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:54.701
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:54.706
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:55.686
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:55.687
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:55.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:55.688
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:55.689
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:55.691
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:55.702
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:55.707
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:56.687
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:56.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:56.689
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:56.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:56.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:56.692
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:56.705
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:56.710
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:35:57.679
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:35:57.681
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:35:57.683
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:57.683
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:35:57.684
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:57.686
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:35:57.715
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:35:57.724
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.40	192.168.1.165	27/03 08:35:58.675
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:35:58.676
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40	192.168.1.165	27/03 08:35:58.679
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:58.680
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:35:58.681
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:58.682
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.40	192.168.1.165	27/03 08:35:58.702
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:35:58.708
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:35:59.691
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:35:59.692
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:35:59.693
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:35:59.694
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:35:59.695
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:35:59.695
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:35:59.707
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:35:59.716
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.40	192.168.1.165	27/03 08:36:00.675
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:00.686
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40	192.168.1.165	27/03 08:36:00.736
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.40 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:00.739
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:00.741
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:00.741
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.40	192.168.1.165	27/03 08:36:00.747
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:00.759
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:36:01.676
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:01.678
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:36:01.678
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:01.679
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:01.681
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:01.681
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:36:01.715
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:01.768
<7>ESP_Easy EspEasy: WD   : Uptime 1 ConnectFailures 0 FreeMem 16784	192.168.1.165	27/03 08:36:02.400
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:02.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:02.684
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:02.685
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:02.686
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:02.690
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:02.691
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:02.703
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:02.708
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:36:03.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:36:03.678
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:36:03.686
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:03.690
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:36:03.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:03.692
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:36:03.737
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:36:03.744
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:04.687
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:04.687
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:04.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:04.690
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:04.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:04.691
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:04.702
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:04.712
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:36:05.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:36:05.678
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:36:05.679
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:05.680
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:36:05.682
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:05.683
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:36:05.703
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:36:05.708
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:06.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:06.677
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:06.678
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:06.716
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:06.717
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:06.718
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:06.774
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:06.782
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:07.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:07.681
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:07.682
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:07.683
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:07.683
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:07.685
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:07.704
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:07.710
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:36:08.694
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:08.710
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:36:08.712
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:08.713
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:08.714
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:08.715
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:36:08.722
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:08.728
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:36:09.687
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:36:09.687
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:36:09.693
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:09.703
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:36:09.704
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:09.705
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:36:09.712
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:36:09.717
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:36:10.676
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:36:10.677
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:36:10.679
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:10.680
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:36:10.681
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:10.682
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:36:10.705
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:36:10.711
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:36:11.677
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:11.677
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:36:11.679
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:11.679
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:11.680
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:11.681
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:36:11.703
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:11.707
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:12.687
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:12.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:12.688
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:12.699
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:12.703
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:12.704
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:12.710
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:12.719
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.80	192.168.1.165	27/03 08:36:13.676
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:36:13.677
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80	192.168.1.165	27/03 08:36:13.689
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.80 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:13.690
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:36:13.691
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:13.693
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.80	192.168.1.165	27/03 08:36:13.704
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:36:13.710
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:14.749
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:14.775
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:14.838
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:14.839
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:15.402
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:15.420
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:36:15.681
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.10	192.168.1.165	27/03 08:36:15.682
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:36:15.687
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:15.688
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10	192.168.1.165	27/03 08:36:15.689
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.10 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:15.690
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:36:15.704
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.10	192.168.1.165	27/03 08:36:15.710
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:16.732
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:36:18.904
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:18.913
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:2 milliSeconds	192.168.1.165	27/03 08:36:19.056
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.80	192.168.1.165	27/03 08:36:19.721
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:19.730
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:19.952
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:19.954
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:19.955
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:19.957
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:19.958
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:19.960
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:19.978
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:19.987
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:21.056
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:21.126
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:21.133
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:21.136
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:36:21.141
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:21.150
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.70	192.168.1.165	27/03 08:36:21.952
<7>ESP_Easy EspEasy: DHT  : Humidity: 27.00	192.168.1.165	27/03 08:36:21.954
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70	192.168.1.165	27/03 08:36:21.955
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.70 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:21.957
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00	192.168.1.165	27/03 08:36:21.959
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=27.00 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:21.960
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.70	192.168.1.165	27/03 08:36:21.981
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 27.00	192.168.1.165	27/03 08:36:21.988
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:22.953
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:22.955
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:22.956
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:22.958
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:22.962
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:22.964
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:22.981
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:22.989
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:36:23.966
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:23.967
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:36:23.968
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:23.970
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:23.972
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:23.978
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:36:23.985
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:23.993
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:24.952
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:24.954
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:24.954
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:24.956
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:24.956
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:24.958
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:24.978
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:24.987
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.50	192.168.1.165	27/03 08:36:25.952
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:25.953
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50	192.168.1.165	27/03 08:36:25.954
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.50 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:25.955
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:25.956
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:25.957
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.50	192.168.1.165	27/03 08:36:25.978
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:25.982
<7>ESP_Easy EspEasy: DHT  : Temperature: 16.60	192.168.1.165	27/03 08:36:26.952
<7>ESP_Easy EspEasy: DHT  : Humidity: 26.90	192.168.1.165	27/03 08:36:26.953
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60	192.168.1.165	27/03 08:36:26.953
<7>ESP_Easy EspEasy: EVENT: DHT#temperature=16.60 Processing time:4 milliSeconds	192.168.1.165	27/03 08:36:26.955
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90	192.168.1.165	27/03 08:36:26.955
<7>ESP_Easy EspEasy: EVENT: DHT#humidity=26.90 Processing time:3 milliSeconds	192.168.1.165	27/03 08:36:26.956
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/temperature 16.60	192.168.1.165	27/03 08:36:26.979
<7>ESP_Easy EspEasy: MQTT : homeassistant/sensor/ESP_Easy/1/humidity 26.90	192.168.1.165	27/03 08:36:26.983
Does anyone have an idea how I limit it to once a power cycle?
Micha_he
Re: Deep sleep triggers multiple MQTT publish
#2 Post by Micha_he » 27 Mar 2018, 09:09
What is configured for device-"Delay" ?
Because this is basically an interval, a low value produces more publish-repetitions.
rutberg
#3 Post by rutberg » 27 Mar 2018, 11:51
Thanks for the input!
I'll have a check when I get home, but this passage in the wiki suggests that it shouldn't be a factor:
It will send all the sensor-readings at once (delays are ignored, except for Message Delay at the advanced settings page)
Micha_he
#4 Post by Micha_he » 27 Mar 2018, 12:24
But in my opinion, program code and wiki currently do not match in all cases (e.g. First boot with RST, DeepSleep Awake Time, Device-Delay).
#5 Post by grovkillen » 27 Mar 2018, 12:29
Yes, alot is happening and we struggle to keep up the wiki. So it's still a R120...mega2.0.0 transition which is not good in the user perspective. I'm sorry but we'll try to get things up to speed once the mega is released as official 2.0.0.
rutberg
#6 Post by rutberg » 27 Mar 2018, 12:37
Alright, good to know! So there could be an option to decrease the wake-time?
If I put it at, for example 1, will it wait until it finishes all sensors or does that risk cutting the process short instead?
Micha_he
#7 Post by Micha_he » 27 Mar 2018, 12:52
A good question. I don't know...
My problem is the Device-Send-Boot-State to the MQTT actual doesn't work (on my ESP-01). And in this context I use a Awake-Time from 15s and a Device-Delay from 10s, for a single publish. And there the Device-Delay seems to work !?
rutberg
#8 Post by rutberg » 28 Mar 2018, 09:56
I've now reduced Awake Time to 1, and the number of updates have dropped to 2 for each cycle. Is there any way of using a rule or similar to go to deep sleep after one update, much like what is described in the wiki?
Users browsing this forum: Ahrefs [Bot], Anthropic Claude Bot [bot], opensiteexplorer.org/dotbot [bot] and 23 guests
