SoftSerial
arnoldg
SoftSerial
#1 Post by arnoldg » 27 Mar 2018, 21:01
I'm trying to develop a dimmer which is controlled by serial.
For this i use softserial on puin D1 and D2
But when i compill all looks good, but it isn't working.
What could be wrong ?
for testing purpose the esp should spit out the whole alfabet, but this isn't working.
on the TX and RX pin's i connected a serial to USB print to monitor the serial port.
and yes TX and RX are connected the right way.
this is when i upload the softserial example it is working !
//#################################### Plugin 200: Dimmer ##################################################
#define PLUGIN_200
#define PLUGIN_ID_200         200
#define PLUGIN_NAME_200       "Dimmer 230V "
#define PLUGIN_VALUENAME1_200 "Dimmer"
#define MinDim                15
#define MaxDim                250
#include <SoftwareSerial.h>                     // to use pin 4 and 5 as RX and TX ports
SoftwareSerial DimSerial(D1,D2,false,256); // RX, TX
boolean Plugin_200_init = false;
boolean Plugin_200(byte function, struct EventStruct *event, String& string)
  boolean success = false;
  switch (function)
    case PLUGIN_DEVICE_ADD:
        Device[++deviceCount].Number = PLUGIN_ID_200;
        Device[deviceCount].Type = DEVICE_TYPE_SINGLE;
                Device[deviceCount].VType = SENSOR_TYPE_SWITCH;
        Device[deviceCount].SendDataOption = false;
    case PLUGIN_GET_DEVICENAME:
        string = F(PLUGIN_NAME_200);
        case PLUGIN_WEBFORM_LOAD:
            success = true;
        case PLUGIN_WEBFORM_SAVE:
              success = true;
      case PLUGIN_INIT:
          DimSerial.begin(9600);
          addLog(LOG_LEVEL_INFO, F("Dimmer: Init OK "));
  for (char ch = ' '; ch <= 'z'; ch++) {
    DimSerial.write(ch);
  DimSerial.println("");
          case PLUGIN_READ:
              // This routine does not output any data and so we do not need to respond to regular read requests
              success = false;
      case PLUGIN_WRITE:
        String log = "";
        String command = parseString(string, 1);
        byte payload = (event->Par2 * 2.55);
        if (payload<MinDim) { payload = 0; };
        if (payload>MaxDim) { payload = 255; };
        String status = "Command : "+ command + ",    Payload : " + payload;
        addLog(LOG_LEVEL_INFO, status);
        if (command == F("dim"))
          DimSerial.write(payload);
          log = String(F(" Set Dim level to ")) + String(payload);
          addLog(LOG_LEVEL_INFO, log);
        success = true;
  return success;
toffel969
Re: SoftSerial
#2 Post by toffel969 » 28 Mar 2018, 13:28
Is i2c activated on D1+2? That would be the default settings
arnoldg
Re: SoftSerial
#3 Post by arnoldg » 29 Mar 2018, 07:04
Thanks,
That was the problem, i overlooked it for 3 days :oops:
toffel969
Re: SoftSerial
#4 Post by toffel969 » 29 Mar 2018, 09:11
arnoldg wrote: 29 Mar 2018, 07:04 Thanks,
Great :) ! Glad to have been of assistance.
Users browsing this forum: Anthropic Claude Bot [bot] and 9 guests
