MQTT import ??
Asco
MQTT import ??
#1 Post by Asco » 23 Sep 2018, 18:11
I would like to use the plugin "MQTT import" on a ESPeasy_01 module to get sensor values from another ESPeasy_02 device.
I have read a lot of post about this but can't understand how to use the plugin, perhaps someone can help me please ? ;)
using red-node debug I can get:
23/09/2018 à 12:01:33node: bf8fd352.782658domoticz/in : msg.payload : string[57]
"{"idx":225,"RSSI":10,"nvalue":0,"svalue":"21.30;58.40;1"}"
This is from a ESPeasy_01 who send DHT22 reading to a Domoticz server, it can correctly get the 2 values in Domoticz
How can I get thoses datas in the second ESPeasy, does using the pluggin MQTT import the good way to do that?
Thank you in advance!!
chris
Re: MQTT import ??
#2 Post by grovkillen » 23 Sep 2018, 18:34
MQTT import is simple so you cannot use JSON formatted messages, only a single float value is supported.
If I where you I'd use rules and push a simple messages on change of that first device. Then on the receiving unit I'd just subscribe to the topic.
Asco
Re: MQTT import ??
#3 Post by Asco » 23 Sep 2018, 19:47
Hello grovkillen,
Thank you for your help,
As you can understand I'm very new to MQTT :)
I don't understand what you mean by "push a simple message" and I don't understand "subscribe to the topic" :roll: :roll:
... SO I think I have to read more about espeasy before coming back to ask a question.
Chris
Asco
Re: MQTT import ??
#4 Post by Asco » 24 Sep 2018, 14:54
I have been able to write rules to publish from ESP_02 the 2 datas I need to read on the other ESP:
chris@L750D:~$ mosquitto_sub -h 192.168.1.3 -t ESP_02_BALANCE/#
"poidsLili":2.20
"poidsMiha":3.10
On the ESP which has to receive the datas I have set a controller:
and a device:
But I can't get poidsMiha and poidsLili on the second ESP.
Can you help me with this?
Chris
Re: MQTT import ??
#5 Post by grovkillen » 24 Sep 2018, 15:00
MQTT Import is kinda its own client. You will set the subscription inside the task settings, not the controller settings.
Asco
Re: MQTT import ??
#6 Post by Asco » 24 Sep 2018, 15:04
Thank you grovkillen,
is there an example somewhere, I am able to use MQTT with node-red, domoticz and mosquitto, but can't understand how it works with ESPeasy ?
I think there is something wrong with phpBB ;impossible to put 2 images inline..
Re: MQTT import ??
#7 Post by grovkillen » 24 Sep 2018, 15:09
Regarding attached pictures, you should just upload them and the forum will place then in the end.
I will need to put some love to the wiki regarding MQTT import. I'll give you a holler once it's done.
Asco
Re: MQTT import ??
#8 Post by Asco » 24 Sep 2018, 15:15
Thank you very much :) !!
Users browsing this forum: Anthropic Claude Bot [bot], Perplexity.ai [bot] and 2 guests
