I am running here on my heater system an additional ESP to calculate the Delta-T from the water in / out so that i would be able to keep this at an optimal level so condensation (gas heater) is optimal.
This all works great by reading the in / out temperature and substracting them and dump the result into a dummy sensor.
But from time to time i get some nasty spikes and since all is stored into a DB to create visualisation with Grafana it looks not so nice
My idea is to filter these spikes out somehow with a potential rule within the ESP but i could not find anything specific then just do an action if value = > XX Level
The setup:
ESP: (See the black marked area's)
Grafana: (See the red marked area these are the spikes i want to get rid of)
The current rule to fill the Dummy sensor:
On Living_Radiator_In#Temp_3 do
TaskValueSet 7,1,[Living_Radiator_In#Temp_3]-[Living_Radiator_Out#Temp_4]
Question is: How to filter these sudden drops ....
Jerome
