Hi all,
on and ESP12 I have rules running 2 events. From domoticz I send a eventClose and eventOpen command. This sets off few relays closing or opening a door for a few seconds and releases the relay again not to keep power on the actuator all the time.
up to ESPEasy_mega-20180915 all worked perfectly. When I load ESPEasy_mega-20181029 or ESPEasy_mega-20181022 I see the event coming in but it does not run the actual event.
So what I did is that it had ESPEasy_mega-20180915 on it and wanted to upload the latest firmware. I started with today's firmware. When it was not working I went down to ESPEasy_mega-20181022, same result. As I did not have all of them I went down to ESPEasy_mega-20181004 and it worked. I could not find any remarks this should not work anymore.
Do any of you have an idea?
Mijn.Handen.
ESPEasy_mega-20181029 events
Re: ESPEasy_mega-20181029 events
Have you saved the rules file after the update?
