Shelly Wifi operated relay switch
Posted: 05 Nov 2018, 12:44
by vojtishek
Hi all,
any idea how to get nice wifi relay switch into ESP Easy which will perfectly fit into wall mount inside existing wall switch?
https://shelly.cloud/product/shelly-1-open-source/
Or at least into domoticz
Vojta
Re: Shelly Wifi operated relay switch
Posted: 05 Nov 2018, 12:48
by grovkillen
Many users have flashed and operate the shelly1 with ESP Easy
Posted: 05 Nov 2018, 13:42
by enesbcs
Shelly stock firmware also works with Domoticz with a python plugin:
https://github.com/enesbcs/Shelly_MQTT
Otherwise there are a simple ESP8266 inside with 2MB flash, you can flash ESPEasy to it.
Posted: 05 Nov 2018, 14:06
by vojtishek
Thanks guys, really quick answers.
I'm going to buy them
Posted: 05 Nov 2018, 15:21
by grovkillen
We even ship a custom firmware file with our nightly releases.
Posted: 19 Nov 2018, 23:51
by megamarco83
grovkillen wrote: ↑05 Nov 2018, 15:21
hi, why shelly is not anymore included in the latest version of releases??
i take the opportunity to ask the difference between the "standard" ( ESP_Easy_mega-20181117_normal_ESP8266_1024) vs:
ESP_Easy_mega-20181117_normal_core_241_ESP8266_1024
ESP_Easy_mega-20181117_test_ESP8266_4096_VCC
ESP_Easy_mega-20181117_minimal_ESP8266_1024_OTA
ESPEasy_2step_UploaderMega_1024
and last question: why there is no more the PUYA build for sonoff basic marked on pcb "Sonoff Basic R2 v1.0 2017-10-11" ??
thanks
Posted: 20 Nov 2018, 06:01
by grovkillen
Shelly should be part of the release. If not we need to fix it.
Special PUYA builds are not needed anymore. Thanks to uzi18 we now have a dynamic patch which is applied on all builds. So no need for special versions.
Posted: 20 Nov 2018, 06:16
by MiKa1975
all shelly products are build on ES8266?
Regards,
MiKa
Posted: 20 Nov 2018, 06:25
by grovkillen
Yes but 2M memory.
Posted: 20 Nov 2018, 10:53
by megamarco83
grovkillen wrote: ↑20 Nov 2018, 06:01
no, i do not see shelly inside the last build...
and related to difference from the "standard version" and those:
thanks
Posted: 20 Nov 2018, 10:56
by MiKa1975
grovkillen wrote: ↑20 Nov 2018, 06:25
Yes but 2M memory.
Have someone pictures from inside of this modules?
Posted: 20 Nov 2018, 20:51
by enesbcs
MiKa1975 wrote: ↑20 Nov 2018, 10:56
Yes but 2M memory.
Shelly1:
esptool.py v2.0.1
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266
Uploading stub...
Running stub...
Stub running...
Manufacturer: ef
Device: 4015
Detected flash size: 2MB
Hard resetting...
Send me a photo camera and i will do some picture..
As long as this happens, my phone can produce the following pictures.
Shelly1: (ESP8266EX based)
Shelly2: (ESP8266EX based)
Shelly4: (not ESP based!)
Some other pictures...
Posted: 21 Nov 2018, 05:59
by MiKa1975
Thanks for pictures
I thing upgrade to 4MB will be just for few cents
https://www.ebay.com/itm/10pcs-W25Q32FV ... 2749.l2649
Regards,
MiKa
