ESP Easy 0.96" OLED set contrast with a button on NodeMCU
Mav63
#1 Post by Mav63 » 17 Feb 2019, 15:22
Hello everybody,
I run current ESP Easy on a NodeMCU (LoLin V3) with an DHT22 and a 0,96 OLED connected. Everything works fine so far.
I am able to set the display contrast through the web interface.
Now it would be great, if I am able to connect a switch which goes through the states (i.e. "On/hight contr."; "On/medium contr."; "On/low contr."; "Off").
Since I am a newbie I need to ask if such is possible at all and, if yes how to do it.
Thanks for all help
/Mav
Wiki
Re: ESP Easy 0.96" OLED set contrast with a button on NodeMCU
#2 Post by Wiki » 18 Feb 2019, 02:13
Yes, it is possible at all, pretty easy using the rules functionality of espeasy.
Sorry, at this daytime I'm too tired to post a detailed example using a button, just a short example how to set the contrast depending on daytime:
On Clock#Time=All,21:00 do
  OLEDFRAMEDCMD,low
On Clock#Time=All,19:00 do
  OLEDFRAMEDCMD,medium
On Clock#Time=All,08:00 do
On Clock#Time=All,9:30 do
  OLEDFRAMEDCMD,high
Probably it might help to have a look at https://www.letscontrolit.com/wiki/inde ... rial_Rules
Before being able to use the rules you have to enable it in Tools/Advanced
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
Mav63
#3 Post by Mav63 » 18 Feb 2019, 16:21
Thank you so much!
It is working!!
So now I am facing next challenge:
Am I able to find the current setting on contrast?
This is because I like to use the push button to toggle between the states (on-high; on-med; on-low; off).
Therefore I need to know the current state to choose the one I like to fire.
Thanks again!
/Mav63
Mav63
#4 Post by Mav63 » 19 Feb 2019, 12:17
Solved with a Dummy device...
But need to press push button sometimes multiple time to get effect.
My rules:
On Button#Switch=toggle do
  IF [Dummy#Wert1]=1
    TaskValueSet 4,1,2
  ELSE
    IF [Dummy#Wert1]=2
      OLEDFRAMEDCMD,high
      TaskValueSet 4,1,3
    ELSE
      OLEDFRAMEDCMD,low
      TaskValueSet 4,1,1
    ENDIF
  ENDIF
I do not evaluate Value of 3 because having Dummy set to 1 in all other cases than 1 or 2.
The interval of Dummy device is set to 1 sec. and of OLED device to 5 sec. which lowers the amount of pressing push button in short time to get result.
Any idea to get a (not) each click get a result issue?
/Mav
