ads1115 differential read
-=niki=-
#1 Post by -=niki=- » 24 Feb 2019, 21:25
I have got this Sensor:
https://www.te.com/commerce/DocumentDel ... T-MIPS0003
Input Voltage: 10V
Outputvoltage 0 - 100mV
Ardiuno + ADS1115 differentail read works great
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads;  /* Use this for the 16-bit version */
//Adafruit_ADS1015 ads;     /* Use thi for the 12-bit version */
void setup(void)
  Serial.begin(9600);
  Serial.println("Hello!");
  Serial.println("Getting differential reading from AIN0 (P) and AIN1 (N)");
  Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV/ADS1015, 0.1875mV/ADS1115)");
  // The ADC input range (or gain) can be changed via the following
  // functions, but be careful never to exceed VDD +0.3V max, or to
  // exceed the upper and lower limits if you adjust the input range!
  // Setting these values incorrectly may destroy your ADC!
  //        ADS1015  ADS1115
  // ads.setGain(GAIN_TWOTHIRDS);  // 2/3x gain +/- 6.144V  1 bit = 3mV      0.1875mV (default)
  // ads.setGain(GAIN_ONE);        // 1x gain   +/- 4.096V  1 bit = 2mV      0.125mV
  // ads.setGain(GAIN_TWO);        // 2x gain   +/- 2.048V  1 bit = 1mV      0.0625mV
  // ads.setGain(GAIN_FOUR);       // 4x gain   +/- 1.024V  1 bit = 0.5mV    0.03125mV
  // ads.setGain(GAIN_EIGHT);      // 8x gain   +/- 0.512V  1 bit = 0.25mV   0.015625mV
  // ads.setGain(GAIN_SIXTEEN);    // 16x gain  +/- 0.256V  1 bit = 0.125mV  0.0078125mV
  ads.begin();
void loop(void)
  int16_t results;
  /* Be sure to update this value based on the IC and the gain settings! */
  //float   multiplier = 3.0F;    /* ADS1015 @ +/- 6.144V gain (12-bit results) */
  float multiplier = 0.1875F; /* ADS1115  @ +/- 6.144V gain (16-bit results) */
  results = ads.readADC_Differential_0_1();
  Serial.print("Differential Voltage: "); Serial.print(results * multiplier); Serial.println(" mV, ");
  delay(1000);
So far so good, but the messurement with esp01 and ESPeasy fails. Any ideas why?
I also didn't get the point "Callibration" ... is there an example how to use it? But I think it won't help me, cause my differentail Readings on A0 to A1 is floating
-=niki=-
Re: ads1115 differential read
#2 Post by -=niki=- » 26 Feb 2019, 22:23
Sry... my mistake ... used unisolated 3.3V rail
