How to send ALL devices status to controller
foxejoe
#1 Post by foxejoe » 02 Mar 2019, 09:41
I would like to Publish (refresh) all devices status to controller with an event or command.
As far as I know the simplest way is to create an event in a rule and publish any single device value (i.e)
on sendDeviceUpdate do
Publish /%sysname%/Device1/Name,[Device1#Name]
Publish /%sysname%/Device2/Name,[Device2#Name]
Publish /%sysname%/Device3/Name,[Device3#Name]
...and so on
Since I have 30 ESP with several Devices, I am looking for a single command which can be the same for all ESP regardless of name or number of devices.
Is it possible? Any idea?
Lorenzo
dynamicdave
Re: How to send ALL devices status to controller
#2 Post by dynamicdave » 02 Mar 2019, 10:25
What you're doing looks like a good solution.
Getting each unit to listen for a common or global event-trigger...
Publish /%sysname%/feedback, [status_information]
I label each of my Wemos D1 Mini modules (ESP8266-based modules) with a unique node name.
e.g. node30, node31, etc...
So the above publish command would send a unique message via MQTT to your main controller (in my case a Raspberry Pi 3+ running Node-RED).
Users browsing this forum: Google [Bot] and 14 guests
