Flashing errors.
Hairyloon
Flashing errors.
#1 Post by Hairyloon » 28 May 2019, 01:14
Trying to flash an ESP-01 with the ESP Easy flasher, it reports errors:
[27/05/2019 22:18:51] wrote 992, requested 1040
[27/05/2019 22:18:51] error: failed sending 1040 bytes
Repeated many times over.
Have tried a few times, and dropped the baud rate to 9600, but get the same. Is it just a duff module or can anything be done?
rayE
Re: Flashing errors.
#2 Post by rayE » 28 May 2019, 02:11
Not sure if this will help but first flash a blank 1M bin before flashing the main app.
Hairyloon
#3 Post by Hairyloon » 28 May 2019, 02:46
Thank you. I have read that that is often good advice. Alas not this time, I get the same error.
rayE
#4 Post by rayE » 28 May 2019, 02:55
Is the ESP01 1M and not 512? Read the number on the flash chip.
Hairyloon
#5 Post by Hairyloon » 28 May 2019, 10:44
Good answer, but I think no. It says P25080H, which I believe is 1MB.
Let me just try something else...
#6 Post by TD-er » 28 May 2019, 10:49
Most ESP01 modules have a PUYA chip. For example the core library is patched to work around the strange write behavior of those chips.
I am not sure if the flasher is 100% compatible with those chips.
You could try the Python based ESP flash tool used in the development tools (Arduino/PlatformIO).
Hairyloon
#7 Post by Hairyloon » 28 May 2019, 11:43
Sorry, I'd made a silly mistake on the flashing circuit. :oops:
I have another module which I suspect is totally dead: lights up blue and doesn't respond to anything: not even reset. That one is scrap?
sillylibyan
#8 Post by sillylibyan » 05 Jun 2019, 11:47
It is considerably easier once its set up so rip the band-aid off and get it done
