DS18B20 stuck for a long time
I have an IoT Beehive and I have the problems with all 3 DS18B20 temperature sensores in it. All were working well but started to get stucked for a long time after some firmware upgrade (unfortunately I do not remember the last version when it was working).
Temperatures should be updated each 5 to 12 seconds - time to time is it working well but then sudenly the last value frozens for some time - sometimes a few minutes, sometimes several hours. Any idea what to do/check to fix it?
You can check the behaviour here http://itrubec.cz/monitor/iotbeehive-ibm-roof-en.php (Temp.swarm and both Heat pads temperatures are from DS18B20s).
Re: DS18B20 stuck for a long time
After that update, did you make sure that the settings worked? What I mean is that you could need to go into the settings and look and see if the address + resolution is the same as it was before the update. If not save the settings once again.
Sensors' addresses are unchanged. I played with the resolution as well as the read frequency but with no impact. It works for a while, then it stops working (without any to me visible/known reason or patern) and then in some time starts to work again. Seems like completely stochastically.
Ok, please look through this thread and see if it what happened to your setup: https://github.com/letscontrolit/ESPEasy/issues/2745
I looks like my case (unfortunately I am not nearby the device now, so I can not check logs). Just - I have also one DHT22 aplied there- and it seems to be working fine.
Ok, good to know. Thanks
Actually running ESP_Easy_mega-20191208_normal_ESP8266_4M1M.bin
Look at this strange beviour:
1) it should send data each minute - there are different gaps (green marker)
2) One DS (Temp.swarm) did not read any value (0) since restart at about noon to 16:21, then read 22,8°C an got stucked with that value (yellow marker)
3) Heating pad 1 has been stucked with 33,5°C till the very same time the Temp. swarm value changed - and then started to work (value is changing - pink marker)
4) While Heating pad 2 is still stucked with 23,5°C (orange marker)
