Keypad MQTT on ESP
Curtis777
Keypad MQTT on ESP
#1 Post by Curtis777 » 29 Dec 2019, 17:22
Hey Guys,
I got stucked.
I plugged a keypad as picture attached.
PCF8574 with GPIO 0 and GPIO 2
and setup my MQTT
all i want is that every keyinput should be reported to my MQTT Broker
connection to my broker is working
but the states are not reported to the MQTT Broker i only see the state -1 which i setted as startup script
Re: Keypad MQTT on ESP
#2 Post by TD-er » 29 Dec 2019, 22:15
The images are not visible.
Curtis777
#3 Post by Curtis777 » 05 Jan 2020, 18:02
#4 Post by TD-er » 05 Jan 2020, 18:57
Why not use a keypad plugin for this?
Curtis777
#5 Post by Curtis777 » 05 Jan 2020, 19:16
good question i never knew there are some plugins.
ill try when the wiki is available again.
i dont know how to use plugins yet
#6 Post by TD-er » 05 Jan 2020, 19:27
You can also use the Read The Docs: https://espeasy.readthedocs.io/en/lates ... lugin.html
Curtis777
#7 Post by Curtis777 » 05 Jan 2020, 19:32
ok found it but dont know how to add them in my existing espeasy firmware
#8 Post by TD-er » 05 Jan 2020, 22:07
Just use the build in which they are include (normal/test/dev)
Curtis777
#9 Post by Curtis777 » 06 Jan 2020, 12:20
i get exactly the same.....
no effect on pressing any button
budman1758
#10 Post by budman1758 » 06 Jan 2020, 18:19
Curtis777 wrote: 06 Jan 2020, 12:20 i get exactly the same.....
If the plugin is working you will get an event in the log. You then need rules to act on the event. Unless you changed the label in the device page you will get
the event "ScanCode" with a 2 digit value. You need to write some rules to do anything from that event. See the code notes at the top of this page.
https://github.com/letscontrolit/ESPEas ... KeyPad.ino
