Esp-01: easy solution tp use 3 GPIO ?
tparvais
#1 Post by tparvais » 09 Feb 2020, 23:08
I’m recycled old,esp-01 to monitor 2 pulse counters and one ds18b20. Programmation firmware last Build is fine
I tried to use gpio 0, 2 and 3
When configuring on gpio 3 the ds18b20 or pulse counter it doesn’t not work
Is there a trick to release this port 3?
Thank’you
budman1758
Re: Esp-01: easy solution tp use 3 GPIO ?
#2 Post by budman1758 » 10 Feb 2020, 00:03
You need to disable the serial port to use GPIO 3. After that it should work.
tparvais
#3 Post by tparvais » 10 Feb 2020, 23:21
oh yes, I forgot that ! Thank you
Could be nice to add it ti wiki
Thomas
