i noticed that regarding wemos D1 mini lots of options are available with either header connectors(which are included) or daughter pcb's
for the nodemcu's (V2 and V3) i can not find anything.
just a simple pcb with headers should do the trick but nothing exists, you need to make everything yourself and even standard pcb's do not have the right size(15 holes x 12 holes)
am i missing something or is it true that nothing exists?
is there a nodemcu v3 socket available
Re: is there a nodemcu v3 socket available
Yes, indeed.
Search Ali with "nodemcu breadboard"
I use one of these:
https://nl.aliexpress.com/item/32966490 ... web201603_
and from this one, to a breadboard.
I use one of these:
Or use this less wide bottom version V2 Nodemcu-CP2102:
Bottom version 48mm* 25mm instead of the top version 57mm * 31mm
https://nl.aliexpress.com/item/32665100 ... 4c4dD77Bii
yes i have that one.
good for testing but i need something for final results
eg with the wemos board you can solder everything on the board
i now use header connectors and solder everything on those but since the 2 header connectors are not mounted to each other the components float
Users browsing this forum: Bing [Bot] and 11 guests
