Hi iam running a r78, but i set a roung IP address, hot to clear it.
If i upload the r78 again its just use the old setting
Its a Black esp 01 module.
How to clear the settings in R78
5xESP-01 - 3xESP-12 - 2xESP-12E 3xRPIb+ - 1xBPIm1 - 3xACTi DOME - 7xACTi Indoor cam. Lot off cisco equ.
Re: How to clear the settings in R78
the devs know all the secrets,
but if you have a serial-console to the esp, you could try typing in there the command: "erase" (only this letters),
another one:
another one:
If RX and TX tied together, perform emergency reset to get the system out of boot loops
How about writing the wiki about the things you can do with a serial connection?
yes,
+1 for wiki additions
but, this here seems SOLVED
If you have access to a linux machine, connect it up and use the esptool script:
esptool.py --port /dev/ttyUSB0 erase_flash
This basically formats the flash, you also have to reupload the firmware. This cleared my settings which were not cleared by serial commands. Also fixed wdt reset crashing due to some corruption in the flash memory.
