Board is placed inside a wall, and sensors are one for each room (two rooms share the same wall).
The sensors in a way similar to this:
Before sending the value via MQTT I'm calculating the average from 10 readings like so:
On Kitchen#Temperature Do
Let,10,[VAR#9]
Let,9,[VAR#8]
Let,8,[VAR#7]
Let,7,[VAR#6]
Let,6,[VAR#5]
Let,5,[VAR#4]
Let,4,[VAR#3]
Let,3,[VAR#2]
Let,2,[VAR#1]
Let,1,[Kitchen#Temperature]
TaskValueSet,3,1,([VAR#1]+[VAR#2]+[VAR#3]+[VAR#4]+[VAR#5]+[VAR#6]+[VAR#7]+[VAR#8]+[VAR#9]+[VAR#10])/10
EndOn
The communication works, but after looking at the reading I've noticed weird behavior:
When we leave the house there are -2 degrees readings and when we return there are +2 readings.
I've replaced the sensors with new ones (also genuine) and I have the same behavior.
I have no idea what can be the cause of this. No one isn't touching the sensors or blowing hot air at them. When the light are turn on or off I have the same readings, so the electrical switch can't be the cause.
I know DS18B20 are very accured, but I'm sure they can't detect person leaving or entering the house
Not sure what can be the cause of this "issue".
Any advice is more than welcome.
