Servo control slow gradually
Dondolo
#1 Post by Dondolo » 05 Jan 2021, 11:46
I would like to open a box with a servo per rules.
In the first step I was able to solve it like this:
on Rules # Timer = 1 do
 Servo, 0,12,120
  timerSet, 2.30
on Rules # Timer = 2 do
 Servo, 0.12.30
  timerSet, 1.30
The problem is that the lid flies open and closes again after the time has elapsed.
Does anyone have an idea how I can slow it down with rules?
Re: Servo control slow gradually
#2 Post by Ath » 05 Jan 2021, 11:55
Dondolo wrote: 05 Jan 2021, 11:46
 Servo, 0.12.30
  timerSet, 1.30
Are those periods intended in that Servo and TimerSet commands, or a minor mistake?
Wouldn't know how to slow down the servo movement, other than dividing the steps to make into smaller pieces and issue multiple commands (basically a loop, and that's quite complex to do in rules), sorry.
Or request a 'speed' feature (msec to complete the move from current position to new position?) on the Servo command.
Dondolo
#3 Post by Dondolo » 05 Jan 2021, 12:37
Thanks for the feedback!
The periods are arbitrary, I am currently testing the servo function.
Exactly a loop with small steps would be just the thing.
I don't know the speed function, the function could help.
The goal is really just to slowly open the lid and close it accordingly.
#4 Post by Ath » 05 Jan 2021, 12:49
Your rules as shown have syntax errors, so won't run as intended
Dondolo
#5 Post by Dondolo » 05 Jan 2021, 12:55
Ok, the box lid opens and closes every 30 seconds, just too fast; - ((
Is there any other method?
Which syntax error?
#6 Post by TD-er » 05 Jan 2021, 16:33
You could create a loop in the rules and use a variable to keep track of the current state of the servo.
on openevent do
  let,2,30  // var#1 = cur position, var#2 = target position
  let,3,([var#2]-[var#1])/10  // Step size
  loopTimerSet_ms,1,500,10  // 10 loop steps of 500 msec each
on Rules#Timer=1 do
  let,1,[var#1]+[var#3]
  Servo,0,12,[var#1]
Not tested, so wouldn't be surprised if the sign of [var#3] is wrong, and you should also make sure to initialize the Servo position and [var#1] at boot.
Also it is a good idea to turn off the PWM signal after moving to conserve energy and extend the life of the servo.
You can set the servo to "position" 9000 to turn the servo off.
Dondolo
#7 Post by Dondolo » 05 Jan 2021, 18:28
Hi TD-er,
thank you, I have to understand that first and try it out. Then give feedback.
Thank you very much for now.
Dondolo
#8 Post by Dondolo » 05 Jan 2021, 22:20
TD-er wrote: 05 Jan 2021, 16:33 You could create a loop in the rules and use a variable to keep track of the current state of the servo.
on openevent do
on Rules#Timer=1 do
  Servo,0,12,[var#1]
Hi TD-er,
it works, first attempt the box opens slowly and the servo switches off in the final state.
I think I'm on the right path, thank you again!
on System#Boot do
Servo,0,12,30  // servo cur position
event,openthebox  //start event openthebox
on openthebox do      //event openthebox
let,2,120  // [var#2] = target position Servo_pos. 120
let,1,30  // [var#1] = cur position Servo_pos. 30
on Rules#Timer=1 do
  Servo,0,12,[var#1]
if [var#1]>=120      //target position stop servo
Servo,0,12,9000
//Kontrolle und Verständnis
TaskValueSet 4,1,[var#1]
TaskValueSet 4,2,%eventvalue2%
ekrzychoooo
#9 Post by ekrzychoooo » 19 Feb 2021, 20:14
when I use the command e.g.
Servo, 0.12, 170
and then
Servo, 0.12.9000
sometimes the servo goes to a random position
I watched the waveforms on the oscilloscope and
I propose to change the code in _P001_Switch.ino
switch (event->Par1)
            case 1:
              // IRAM: doing servo stuff uses 740 bytes IRAM. (doesnt matter how many instances)
                #ifdef USE_SERVO
              // SPECIAL CASE TO ALLOW SERVO TO BE DETATTCHED AND SAVE POWER.
              if (event->Par3 >= 9000) {
                servo1.detach();
              } else {
                servo1.attach(event->Par2);
                servo1.write(event->Par3);
                #endif // USE_SERVO
            case 2:
                #ifdef USE_SERVO
                servo2.detach();
              } else {
                servo2.attach(event->Par2);
                servo2.write(event->Par3);
                #endif // USE_SERVO
to
            case 1:
                #ifdef USE_SERVO
                while(digitalRead(event->Par2)==1);
                servo1.detach();
              } else {
                #endif // USE_SERVO
            case 2:
                #ifdef USE_SERVO
                servo2.detach();
              } else {
                #endif // USE_SERVO
#10 Post by TD-er » 19 Feb 2021, 20:35
That's a tricky one.
What if you don't have (no longer) a servo connected or for some reason the pin remains high?
Better to include something like this:
unsigned long timeout = millis() + 100;
while(digitalRead(event->Par2)==1 && !timeOutReached(timeout));
ekrzychoooo
#11 Post by ekrzychoooo » 19 Feb 2021, 20:46
you're right, it will be safer this way
