Send data to Emomcms from rules
hi, i am trying to send data from rules to emocms, and i not want to use controlers
after wasting a lot of time with this I ask for help,
in browser this works fine:
http://192.168.1.109/input/post?node=ES ... 68d01d9454
even this
http://192.168.1.109/emoncms/input/post ... 68d01d9454
but in rules I have tried many combinations and have not been able to make it works
examples i tried
SendToHTTP 192.168.1.109,/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234664c68d01d9454
SendToHTTP 192.168.1.109/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234664c68d01d9454
SendToHTTP 192.168.1.109/input/post?node=ESP_9&fulljson='{"temperatura":77.7}'&apikey=f9a6bad9744c5b7234664c68d01d9454
SendToHTTP 192.168.1.109,emoncms,input,post?node=ESP_9&fulljson='{"temperatura":77.7}'&apikey=f9a6bad9744c5b7234664c68d01d9454
SendToHTTP 192.168.1.109,/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234664c68d01d9454
please, i need help
thanks
even this
examples i tried
please, i need help
thanks
Re: Send data to Emomcms from rules
See for more info: https://github.com/letscontrolit/ESPEasy/issues/2724
So for example first the line you tried and next the line how I think it should be:
The last parameter of "SendToHttp" is the URL and since it has both a comma and quotes, you should wrap the entire parameter in quotes which are not used in the parameter.
SendToHTTP 192.168.1.109,`emoncms,input,post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234664c68d01d9454`
thanks TD-er for you answer but no way
i tried in rules
in rules
// this work on brouser http://192.168.1.109/input/post?node=ES ... 68d01d9454
SendToHTTP 192.168.1.109,'/emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454'
SendToHTTP 192.168.1.109, '/emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454'
SendToHTTP 192.168.1.109,`/emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454`
SendToHTTP 192.168.1.109, `/emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454`
SendToHTTP 192.168.1.109, /input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
SendToHTTP 192.168.1.109, '/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
SendToHTTP 192.168.1.109, "/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454"
SendToHTTP 192.168.1.109,"/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454"
SendToHTTP 192.168.1.109,/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
in log
31553: ACT : SendToHTTP 192.168.1.109,'/emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d0
31565: SendToHTTP connection failed
31571: ACT : SendToHTTP 192.168.1.109, '/emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d
31583: SendToHTTP connection failed
31589: ACT : SendToHTTP 192.168.1.109,`/emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d0
31605: SendToHTTP connection failed
31611: ACT : SendToHTTP 192.168.1.109, `/emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d
31627: SendToHTTP connection failed
31654: ACT : SendToHTTP 192.168.1.109, /input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
31666: SendToHTTP connection failed
31670: ACT : SendToHTTP 192.168.1.109, '/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
31682: SendToHTTP connection failed
31685: ACT : SendToHTTP 192.168.1.109, '/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
31696: SendToHTTP connection failed
31700: ACT : SendToHTTP 192.168.1.109,'/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
31708: SendToHTTP connection failed
31713: ACT : SendToHTTP 192.168.1.109,/input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
31723: SendToHTTP connection failed
in rules
SendToHTTP 192.168.1.109,'emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454'
SendToHTTP 192.168.1.109, 'emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454'
SendToHTTP 192.168.1.109,`emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454`
SendToHTTP 192.168.1.109, `emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454`
SendToHTTP 192.168.1.109, input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
SendToHTTP 192.168.1.109, 'input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
SendToHTTP 192.168.1.109, "input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454"
SendToHTTP 192.168.1.109,"input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454"
SendToHTTP 192.168.1.109,input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
in log
88983: ACT : SendToHTTP 192.168.1.109,'emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d01
88995: SendToHTTP connection failed
89001: ACT : SendToHTTP 192.168.1.109, 'emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d0
89015: SendToHTTP connection failed
89021: ACT : SendToHTTP 192.168.1.109,`emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d01
89033: SendToHTTP connection failed
89038: ACT : SendToHTTP 192.168.1.109, `emoncms/input/post?node=ESP_9&fulljson={'temperatura':77.7}&apikey=f9a6bad9744c5b7234774c68d0
89050: SendToHTTP connection failed
89054: ACT : SendToHTTP 192.168.1.109, input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
89067: SendToHTTP connection failed
89072: ACT : SendToHTTP 192.168.1.109, 'input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
89083: SendToHTTP connection failed
89114: ACT : SendToHTTP 192.168.1.109, 'input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
89126: SendToHTTP connection failed
89132: ACT : SendToHTTP 192.168.1.109,'input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454'
89141: SendToHTTP connection failed
89145: ACT : SendToHTTP 192.168.1.109,input/post?node=ESP_9&csv=77.7&apikey=f9a6bad9744c5b7234774c68d01d9454
89159: SendToHTTP connection failed
no way
any idea?
i tried in rules
in rules
in log
in rules
in log
no way
any idea?
You forgot the port number in the sendtohttp command
host,port,URL
host,port,URL
Emoncms input don´t have ports
this work if you put it in a brouser like crome and there is no port
docu:
https://emoncms.org/site/api#input
docu:
Default http port is port 80.
Thus:
Thus:
SendToHTTP 192.168.1.109,80,'/emoncms/input/post?node=ESP_9&fulljson={"temperatura":77.7}&apikey=f9a6bad9744c5b7234774c68d01d9454'
it is working TD-er
thanks a lot
thanks a lot
You're welcome...
I will try to add a hint in the log if the port was missed as that's something that's easy to overlook.
Hi. A similar situation. I'm trying to send data from the rules to open-monitoring.online.
In the browser, this works fine: http://open-monitoring.online/get?cid=1 ... 3&p4=44444.
But the rules I tried, it doesn't work.
SendToHTTP open-monitoring.online/get?cid=1288&key=io16e4&p1=11111&p2=22222&p3=33333&p4=44444
Or use the site's IP address 109.174.31.9
SendToHTTP 109.174.31.9,80,'/get?cid=1288&key=io16e4&p1=11111&p2=22222&p3=33333&p4=44444'
I need help.
I need help.
Does that site actually accept http protocol or does it forward to https?
Nb: your second SendTHTTP example is correct the first one is incorrect
The site accepts the http protocol.
The rules are written correctly, but they don't work with this site.
I will try to configure another service. Can ESPEasy work with beebotte.com?, have you any experience of its setting up?
Here's a syntax error, the SendToHTTP command needs 3 arguments, not 1
If I separate the site and the rest of the url, inserting ",80," just as below it gets sent.
SendToHTTP open-monitoring.online,80,/get?cid=1288&key=io16e4&p1=11111&p2=22222&p3=33333&p4=44444
Beebotte redirects to https immediately, and ESPEasy doesn't support https by default, so I don't think that'll work.
Hi guys.
but: it looks like the content-MD5 header is required to get a valid signature and this might be an issue. ref.-> https://beebotte.com/docs/auth
This is what i'm struggeling with and wonder also if somebody has it running already properly and how exactly ??
any hint's are welcome.
thx & regards
sm0k0
@Ath : Thats not correct, beebotte is also using non-ssl via port 1883 and ssl on port 8883. ref-> https://beebotte.com/docs/mqtt#auth
thx & regards
sm0k0
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 21 guests
