need help configuring switch
wonk
#1 Post by wonk » 03 Mar 2021, 17:47
I connected a switch TCRT5000 to a NodeMCU with ESPEasy. The optical digtal sensor is looking to a ferraris counter with a turning wheel. Its normaly HIGH and a count is a LOW impulse for some tenth second. As I do not have a special plugin for this switch, I took the normal switch input plugin here: https://espeasy.readthedocs.io/en/lates ... witch-page. I only changed the GPIO data to D6, where my wire is connected. But it does not work. The green value on the devices tap does not change, althouph I see at the device LED, that the status is changing. What data on the device page do I have to alter?
Gruss, wonk
ingoiot
Re: need help configuring switch
#2 Post by ingoiot » 03 Mar 2021, 19:37
can you measure a voltage on the GPIO pin?
also the overview page is not always that fast.
is there something in the logs?
wonk
#3 Post by wonk » 04 Mar 2021, 10:23
sorry, it is the other way: when LED on sensor is ON, the signal is LOW, when LED ist OFF for a short time, signal goes up to 2.5V.
Some log output:
66295831: SW : GPIO=12 State=1 Output value=1
66296917: SW : GPIO=12 State=0 Output value=0
66304351: WD : Uptime 1105 ConnectFailures 6490 FreeMem 19216 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
66325617: SW : GPIO=12 State=1 Output value=1
66326717: SW : GPIO=12 State=0 Output value=0
66334351: WD : Uptime 1106 ConnectFailures 6490 FreeMem 19136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
66347718: SW : GPIO=12 State=1 Output value=1
66347817: SW : GPIO=12 State=0 Output value=0
66357317: SW : GPIO=12 State=1 Output value=1
66358518: SW : GPIO=12 State=0 Output value=0
66364351: WD : Uptime 1106 ConnectFailures 6490 FreeMem 19136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
66392017: SW : GPIO=12 State=1 Output value=1
66393317: SW : GPIO=12 State=0 Output value=0
66394351: WD : Uptime 1107 ConnectFailures 6490 FreeMem 19136 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
What sort of timecode is the first number?
Although there is a switch of output state, I cannot see this in the green value output.
Gruss, wonk
#4 Post by TD-er » 04 Mar 2021, 10:26
The first number is the 'uptime' in msec.
N.B. this may wrap to 0 every 49.7 days :)
ingoiot
#5 Post by ingoiot » 04 Mar 2021, 13:36
maybe this is what you are looking for?
https://espeasy.readthedocs.io/en/lates ... R5000.html
wonk
#6 Post by wonk » 04 Mar 2021, 18:02
thank you, that helps. It is the right plugin, it shows values. But I do not understand configuring. It seems, I can get three values: Delta, Total, Time
What is Delta, Total, Time?
What is the meaning of %value% in this case?
Why do I have to set an interval?
I only know that every 480 turns of the wheel are 1 KWh.
Gruss, wonk
ingoiot
#7 Post by ingoiot » 04 Mar 2021, 20:52
dont knmow how this really works,but im guessing that
setting type to total and mode to change,
activating send single event with all values,
setting the formula to %value%/480
at an intervall of 10 sec.
should give you the total amount of used kwh since last reboot. every 10 seconds.
