ESP Easy Mega measure Wind speed and direct / Ozone / UV index / Solar light
Posted: 09 Dec 2021, 11:27
by mra2ko
someone who would help with the measurement of wind speet and direct, ozone, uv index and daylight (w/m2) ?
Some experience ? Sensors, how to connect and etc... ?
Thank
Re: ESP Easy Mega measure Wind speed and direct / Ozone / UV index / Solar light
Posted: 10 Dec 2021, 13:53
by Ton_vN
Everything can be DIY, but that takes some effort & time:
the interfaces already available in the catalogue of ESPEasy provide plenty of choice.
At the other end of the range, much easier & more economic is to buy a Personal WeatherStation as a package.
Plenty of configurations at 'reasonable' price, although
price & quality have a relation ........
If 'ready-to-go' is not desired, perhaps a 'hybrid'-solution is something to your taste, like
described in Elektor.
For Light & UV then you need to connect selected sensors via the Grove-connectors (plus addition of related software).
Another option for DIY is
Sensebox which you may configure as you like from their catalogue ......
Posted: 10 Dec 2021, 15:28
by Ath
Ton_vN wrote: ↑10 Dec 2021, 13:53
What's the fun in that
Posted: 10 Dec 2021, 16:33
by chemmex
Hi, for wind measurement you can check something in the Misol range of products @Aliexpress. They sell comtlete weather stations, but separate sensors as well, so there's plenty to choose from. And they can interface with ESPEasy.
Ozone sensors are quite different thing, you can find them from Winsen or Alphasense, but they all work in a relatively short temperature/humidity range and require calibration.
UV and light sensors are easy to find, too
Posted: 10 Dec 2021, 21:55
by Ton_vN
@Ath,
Not without reason used the fat text around the text you quoted
Plenty of configurations at 'reasonable' price, although price & quality have a relation ........
Have the impression that most people try to avoid the mechanical aspects in anemometer and rain gauge.
If already purchasing 'serious', mechanical sensors for those functions, perhaps meaningful to incorporate the related 'integration' as well:
still plenty of opportunity/fun to add-on the other elements.
In fact the Elektor-configuration is along that lines, and in the 'mechanical' core is a Misol-collection as mentioned in the previous message:
also sold via AliX (and others) as a PWS.
Posted: 10 Dec 2021, 22:55
by mra2ko
I can use some sensors from old WX... Is also home-made, but i am problem with posting data out from local site. I would like use node-red, mqtt and other, is better...
I found VEML6075 but is not supported in las version fw, anybody know what is not supported?
Some pic from old WX...
- IMG_2446.JPG (1.82 MiB) Viewed 7270 times
- IMG_7929.JPG (1.94 MiB) Viewed 7270 times
- IMG_7948.JPG (1.37 MiB) Viewed 7270 times
