TM1637 7dt
Posted: 20 Apr 2022, 06:43
by Alex P
How to use the 7dt command. At the same time, my display just flashes. At the same time, 7dtext displays the temperature normally. На шине DIO-Pin у меня подключен LED. В автоматическом режиме часы он моргает только при изменении состояния, в ручном режиме моргает постоянно даже если информация не меняется.
Re: TM1637 7dt
Posted: 20 Apr 2022, 07:36
by Ath
Alex P wrote: 20 Apr 2022, 06:43 На шине DIO-Pin у меня подключен LED. В автоматическом режиме часы он моргает только при изменении состояния, в ручном режиме моргает постоянно даже если информация не меняется.
Translation:
Alex P wrote: 20 Apr 2022, 06:43 I have an LED connected to the DIO-Pin bus. In automatic mode, the watch blinks only when the state changes, in manual mode it blinks constantly even if the information does not change.
What pins did you use to connect the display to?
Re: TM1637 7dt
Posted: 20 Apr 2022, 08:26
by Alex P
ESP-01S
Re: TM1637 7dt
Posted: 20 Apr 2022, 08:39
by Ath
And you have not enabled the WiFi led feature? :
Screenshot - 20-04-2022 , 08_37_34.png (6.39 KiB) Viewed 6209 times
Because that will interfere with the display, as you would expect.
Re: TM1637 7dt
Posted: 20 Apr 2022, 09:07
by Alex P
WiFi led feature is disabled, it does not prevent the display from displaying information. Only the 7dt function does not work.
Re: TM1637 7dt
Posted: 20 Apr 2022, 10:10
by Ath
I will have to check to see if there is some anomaly in the code, or something else is going on here, and configure a similar hardware setup. That will take some time (probably a few days, busy schedule, only working on ESPEasy in my spare time ;))
Re: TM1637 7dt
Posted: 20 Apr 2022, 11:05
by Alex P
Thank you. While I use through dtext. But it seems to me that there is some difference in hardware output between auto and manual mode.
Re: TM1637 7dt
Posted: 25 Apr 2022, 06:25
by Alex P
When you enter the command dn, dt, the display only flashes for a fraction of a second.
