Line notify
lcchen12000
Line notify
#1 Post by lcchen12000 » 05 Nov 2022, 10:26
How to add line notify in notifications ???
https://github.com/TridentTD/TridentTD_LineNotify
Thank
Re: Line notify
#2 Post by Ath » 05 Nov 2022, 11:02
That's a bit hard to support at the moment, as ESPEasy only has experimental HTTPS/SSL support, and for the MQTT connection only, for now. And that is also, practically, limited to ESP32, as ESP8266 has quite severe memory (size) limitations to effectively support SSL.
If you could use a proxy that supports http to https transformation for outgoing connections, so you could emulate support by using SendToHTTP commands or one of the HTTP controllers to send out notifications, but until ESPEasy has HTTPS/SSL support included, it won't be possible to address that service directly.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 12 guests
