Bigger LCD 7" +/- and MQTT import
mra2ko
#1 Post by mra2ko » 08 Feb 2023, 11:38
I need bigger LCD and import some numbers from MQTT broker, anybody any solution ?
Nextion or Eink or similar ? Real pic of construction ?
Thank
Re: Bigger LCD 7" +/- and MQTT import
#2 Post by Ath » 11 Feb 2023, 14:37
For LCD/TFT screens of that size, besides the Nextion models, I have only found displays based on the SSD1963 controller (800x480 pixels), and that's not (yet) supported by ESPEasy.
For getting MQTT values on ESPEasy, you can use the MQTT Import plugin. Depending on the build used, not all options like filtering and mapping, might be available though.
bidrohini
#3 Post by bidrohini » 11 Feb 2023, 14:44
You can use a Nextion Enhanced HMI Intelligent Smart USART Serial Touch TFT LCD Module. You can also use an E-Ink (electronic ink) display.
Since you're facing issues with MQQT, you can take a look at this write-up:
https://www.theengineeringprojects.com/ ... -mqtt.html
It discusses broadly about the MQTT protocol. It features ESP32.
#4 Post by Ath » 11 Feb 2023, 14:51
bidrohini wrote: 11 Feb 2023, 14:44 Since you're facing issues with MQQT, you can take a look at this write-up:
That's not what's said, OP just asked how to get values from MQTT on ESPEasy, that's what the MQTT Import plugin is for.
bidrohini wrote: 11 Feb 2023, 14:44 https://www.theengineeringprojects.com/ ... -mqtt.html
Your link is dead (404), but the HiveMQ site has a very elaborate description of the MQTT protocol.
