Cache Reader Plugin
Cache Reader Plugin
Inspired by the 20230304 release notes, I have built a custom image with P146 included, but so far a lot of questions remain.
I'm particularly interested in bulk sending of stored data. TD-er, I realize that writing docs takes even more effort than writing code itself, but can you give an idea of how it is intended to work?
Re: Cache Reader Plugin
It can either re-send trough the original task ("Send Bulk" unchecked) , or it can 'dump' it via MQTT ("Send Bulk" checked)
You can also click on the "Download as CSV" button.
When dumping to MQTT, the taskinfo will be sent to a separate MQTT topic (well at least there is a separate field to set a separate topic is you wish)
There are 2 options for sending it to MQTT:
- Send as HEX encoded binary
- Send as CSV (the same layout as on the CSV file export)
The binary HEX encoded is the same format as how it is stored on the flash and a Python decode script is present in the misc folder to give you some inspiration.
The CSV option dumping to MQTT does also include some header per message to indicate what is to be expected.
- start file nr
- start pos
- end file nr
- end pos
- Nr of CSV lines
- Length in bytes (incl. newline) of the CSV lines
Then what follows is a number of CSV lines, depending on the nr. of tasks included in the dump and the max. message size.
N.B. on ESP8266 do not use large messages due to memory.
You can set the separator and whether you only want to export tasks which have a plugin set to them.
The "Join Samples with same Timestamp" is just what is states.
This will then also be shown in the "PluginID" and "Task index" columns as those will then show which tasks/plugins were combined in the same line.
You can also set a specific timestamp when saving to the cache controller, using the new command "TaskRunAt"
Example rules set:
This is collecting data to several dummy tasks and then flushing it to the cache controller.
- start file nr
- start pos
- end file nr
- end pos
- Nr of CSV lines
Example rules set:
On gps#All Do
Let,4,%unixtime%
LoopTimerSet,1,[int#2] // re-set the timer to have at least [int#2] seconds between samples.
TaskValueSet,gps1,long,[gps#long]
TaskValueSet,gps1,lat,[gps#lat]
TaskValueSet,gps1,alt,[gps#alt]
TaskValueSet,gps1,spd,[gps#spd]
TaskRunAt,gps1,[int#4]
Event,saveAllToFlash
On Rules#Timer=1 Do
Let,4,%unixtime%
On sunrise#All Do
// Copy the last measurement to the dummy task
// Since we have 2 fields left, we also keep the previous value
TaskValueSet,co2,co2_prev,[co2#co2]
TaskValueSet,co2,temp_prev,[co2#temp]
TaskValueSet,co2,co2,[sunrise#co2]
TaskValueSet,co2,temp,[sunrise#T]
TaskValueSet,error,sunrise_prev,[error#sunrise]
TaskValueSet,error,sunrise,[sunrise#err]
On saveAllToFlash Do
// Now collect other data to store into 'dummy' tasks.
// For this, we use the command TaskValueSet.
// See: https://espeasy.readthedocs.io/en/latest/Rules/Rules.html#taskvalueset
// First we get the other values from the GPS unit and store it in the dummy task called "gps2"
// See: https://espeasy.readthedocs.io/en/latest/Plugin/P082.html#access-to-all-measurement-values
// N.B. the first 2 arguments of the TaskValueSet command are resp. the task name and variable name of a dummy task
// So make sure these match with an enabled dummy task
TaskValueSet,gps2,hdop,[gps#hdop]
TaskValueSet,gps2,satvis,[gps#sat_vis]
TaskValueSet,gps2,sattracked,[gps#sat_tr]
TaskValueSet,gps2,chksumfail,[gps#chksum_fail]
// Calling TaskRun will cause the values to be sent to the controller(s) assigned to the task
TaskRunAt,gps2,[int#4]
// Now we collect the latest samples of the analog voltages
TaskValueSet,analog,carBat,[bat#Analog.avg3]
TaskValueSet,analog,backupBat,[batBackup#Analog.avg5]
// And flush them to the Cache Controller
TaskRunAt,analog,[int#4]
// Now we collect the latest samples of the BME280
TaskValueSet,bme2,Temperature,[bme280#Temperature]
TaskValueSet,bme2,Humidity,[bme280#Humidity]
TaskValueSet,bme2,Pressure,[bme280#Pressure]
TaskRunAt,bme2,[int#4]
// Flush current and previous CO2 value to flash
TaskRunAt,co2,[int#4]
// Store the samples from the last reading from the PMS5003
TaskRunAt,pms1,[int#4]
TaskRunAt,pms2,[int#4]
// Collect data from the (optional) Accelerometer
TaskRunAt,adxl345,[int#4]
// Collect some sysinfo
TaskRunAt,sysinfo,[int#4]
// Collect error states
TaskRunAt,error,[int#4]
Thanks a lot.
I am able to save sensor data to the cache files; the question is rather how can I control sending the cached readings to the MQTT. Are there separate commands or it is scheduled by the plugin? So far I am not seeing anything in the logs or at the broker.
To force flushing any 'cache' file on the filesystem, give this command:
To force sending the task info to the MQTT broker:
cachereader,setreadpos,0,0
cachereader,sendtaskinfo
No luck with both commands. Below is plugin setup:
and task info: Log only shows the command itself
but nothing is sent and the cachefile size remains the same
1483080: HTTP: cachereader,setreadpos,0,0
1483086: CacheReader : SetReadPos,0,0
The position in the task info screenshot show you have a FilePos of 1824, so it has been sending something.
Do you have some MQTT explorer to look at topics?
Is the node allowed to publish to these topics?
Is the MQTT controller connected and doesn't loose connection?
Yes to all three questions. The node regularly publishes data from the rules. The broker has no restrictions.
As to the FilePos of 1824, it is also the size of cacheFile, it contains the sensor data collected so far (77 lines in dumped CSV file):
There might (still) be an issue here if the write pointer is the same as the read pointer.
So maybe you can try to power cycle the unit, to make sure the read pos is actually 0.
The read pos and file nr. are stored in RTC memory, so it will be kept even through reboots, but not power cycle.
I will try with a clean config tomorrow.
Thanks and good night!
Please first try a power cycle, to see if it will upload the 1st file.
I think it might no longer be a problem if there are >1 cache files.
It will also continue to upload new samples as soon as they are written to the flash.
N.B. forcing download the CSV file will also trigger to save whatever is still in RTC and can be flushed to flash.
Nothing changed so far after power cycle.
My current config is following:
- two controllers (C005/MQTT and C016/Cache)
- SHT30 sensor task sending data each 20 seconds to Cache Controller
- Cache reader plugin configured as few posts above
- a rule publishing some telemetry data to the broker configured as C005 each minute
I can see that SHT data is cached and file size is growing; I can dump this data as CVS file in the Cache reader plugin interface, everything seems valid
In the plugin, I have Send Bulk checked and MQTT topics configured, also send to C005 controller checked
What is expected but doesn't happen: Cache reader doesn't trigger sending to MQTT, nothing is seen in the log and in the tcpdump
On ESP8266 the RTC memory is very small, like 240 bytes.
So this will flush to the 'cache files' every 10 "samples" (sends to C016)
ESP32 does have a lot more RTC memory, but as some trade-off between not loosing too much data and not wearing out the flash, the data is flushed every 768 bytes (32 "samples")
I find it strange that you don't see anything being written to the MQTT broker, unless the minimal time between messages is set too high. This can be set in the controller and there is a similar setting in the cache reader too.
If you set the minimal interval in the cache reader too low, no other task will be able to send anything to the controller.
Can you add something like this to the rules:
As you can see, by me copy/paste quite extensive rules sets, I have it running on a number of nodes here.
So I really wonder what might be wrong on your config to why it isn't working.
Anyway, do you see the sysinfo being published?
Maybe the data is sent to the MQTT controller before it is connected and with a very short timeout it might already be purged from the queue due to timeouts?
So that's why you might want to trigger such an upload via the MQTT#connected event.
// An event to send the sysinfo.
// This can also be triggered remote to request the sysinfo via MQTT by sending a command like:
// topic: tracker_v2/%sysname%/cmd
// message: event,sendSysinfo
On sendSysinfo Do
publish tracker_v2/%sysname%/sysinfo/sysbuild_filename,"%sysbuild_filename%"
publish tracker_v2/%sysname%/sysinfo/sysbuild_date,"%sysbuild_date%"
publish tracker_v2/%sysname%/sysinfo/sysbuild_time,"%sysbuild_time%"
publish tracker_v2/%sysname%/sysinfo/systime,"%systime%"
publish tracker_v2/%sysname%/sysinfo/unixtime,"%unixtime%"
publish tracker_v2/%sysname%/sysinfo/mac,"%mac%"
// Also send the taskinfo used by the cache reader task.
On MQTT#Connected Do
// Only automatically send the sysinfo the first time the unit connects to the MQTT broker since boot.
If [int#1] = 0
Let,1,1
AsyncEvent,sendSysinfo
In fact, I am publishing some basic system info upon MQTT#Connected, so this part works without problems. Except for this line:Can you add something like this to the rules:
CODE: SELECT ALL
Probably, I missed something in my custom build?
Suddenly, I got it working after full reset of the node, so I am receiving CSV data in the upload topic
